For what its worth: Levinson ML-9 schematic For what its worth: Levinson ML-9 schematic - diyAudio
Old 1st July 2013, 10:53 PM   #1
FootFungus is offline FootFungus  United States
Default For what its worth: Levinson ML-9 schematic
I have never been able to locate a Mark Levinson ML-9 schematic. Attached is a schematic I whipped up in LTSPICE. I think its correct, but caveat emptor. Its just the main amp shown. Missing is the current limiting circuit at the bottom of the amp boards, slow start board, and rear protection board. This is a later model I think.
MPS-A64 in the schematic is MPS-U95 in the amp.
MPS-A14 in the schematic is MPS-U45 in the amp, and one is glued to the top of each TO-3 driver for thermal tracking.
1N4148 in the schematic is 1N914 in the amp.
Old 24th March 2017, 08:55 AM   #2
QSerraTico_Tico is offline QSerraTico_Tico  Europe
QSerraTico_Tico's Avatar
Thanks for very neat schematic.
The power supply voltage is +/- 75V?
Old 24th March 2017, 11:27 AM   #3
Yes. IIRC, the 2N3439 and 2N5416 are mislabeled (swapped).
Old 24th March 2017, 12:53 PM   #4
r_merola is offline r_merola  Brazil
Thank you for your work!
Can you post asc file and library files for this amplifier?
Maybe we can try new devices and even a new clone.
Thank you in advance!
Ronaldo
Old 24th March 2017, 01:29 PM   #5
I'll look for them. You can likely use MJE15032/33 or MJE15034/35 for the 2SC2336/2SA1006. The later series amps use these. The 2X, 33X, and 43X series amps are are evolutions of the same design with the later ones using the MJE15032/33 in a quadruple darlington setup.
For what its worth: Levinson ML-9 schematicHide this!Advertise here!
Mark Levinson ML-2 Problems huy801 Solid State 51 4th March 2014 04:11 AM
Levinson ML-7A RobertS61 Solid State 0 21st May 2013 03:15 PM
Levinson ML-2 distorts randomely RobertS61 Solid State 4 26th October 2011 06:03 PM
Levinson ML-2 or Threshold SA/1 RobertS61 Solid State 0 24th October 2011 09:44 AM
Levinson ML-9 Help? tympani1d Solid State 1 9th December 2009 07:26 PM
Copyright ©1999-2017 diyAudio
