Small 20 watt amp/pre
Old 8th December 2003, 05:41 AM   #1
chuck55 is offline chuck55  United States
Default Small 20 watt amp/pre
Hi all!
I am new to DIY and got referred to this site from Audio Asylum. I did some searching at the kits directory and did not find a small amp/pre combination. So I am posting here to ask for some direction.
I completed my first DIY speaker, the ELF 1.0 from creative sound. It sound nice and since it sits on my mantle, has pretty good bass reinforcement. I was running it on a Denon UD-M31 mini-system. But I enjoy the fun of making things and would like to try making my own "mini-system" to go with the speakers.
The only small size DIY kits I have found are Scott Nixon's stuff. His $100 20 watt mono block amps look good. I would like to hook up to a Radio Shack Alps volume pot as a passive pre and maybe his DAC kit.
Are there other suitable / better small kits available? I enjoy the sound of Creek and Musical Fidelity. NAD and Denon are not too transparent. But enjoyable to listen to nontheless. Teac reference 300 is a bit bright but nice for the money. Eventually I will build a speaker with the Jordan JX92S or the ELF1.5's.
Old 10th December 2003, 06:31 PM   #2
paulb is offline paulb  Canada
I haven't looked specifically, but you might check these guys out:
Old 11th December 2003, 04:28 AM   #3
Thanks for the response. Lots of interesting kits there.
Old 24th December 2003, 11:22 PM   #4
I don't get it. No one can recommend any good kits? Isn't this is do it yourself site?
Old 25th December 2003, 09:20 AM   #5
00940 is offline 00940  Belgium
00940's Avatar
it is.
But most of the guys build things from scrap, just using a schematic.
Old 25th December 2003, 11:30 AM   #6
joensd is offline joensd  Germany
If youre looking for kits specifically you can also check out Elliot Sound Pages.
Project 19&72 are "gainclones" which have good sound.
You can order PCBs but those gainclones are also relatively easy to wire point to point.
They dont need a preamp. You can set the gain through the combination of resistors.
Check out some threads in the "chip amp"-forum for more insight.
Cheers & Merry Xmas
Small 20 watt amp/preHide this!Advertise here!
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 07:51 PM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 02:07 AM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 01:19 PM
Small Monitors, Small Room Seth Smith Multi-Way 0 30th January 2006 05:01 AM
Looking for small 10 watt speakers for embedded device piper984 Parts 6 1st December 2005 09:27 AM
