My New VAS Topology
My New VAS Topology
Old 15th July 2013, 04:56 PM   #121
MagicBox is offline MagicBox  Netherlands
I'm now inclined to make a classic VAS (enhanced for trial's sake) with a TMC using the same OPS as I've been using, as well as the same voltages etc to make it as close as possible for comparission, to compare THD.
Negative Feedback: The Need for Speed
Old 15th July 2013, 05:40 PM   #122
mcd99 is offline mcd99  United Kingdom
What about cherry (Nested loops)? Only throwing this out as an idea.
Old 15th July 2013, 06:06 PM   #123
HarryDymond is offline HarryDymond  United Kingdom
Originally Posted by MagicBox View Post
Harry, no; C3 was part of a snubber that's now gone again.
Sorry, should have been clearer:
I was talking about C3 in the schematic from post #79.
Old 15th July 2013, 06:18 PM   #124
Yeah that's correct, that's the Cmiller.
I now have a version with TMC and I can clearly see the increase in slope on the gain plot, but the phase remains icky. I'm now testing phase margin with a pure capacitive load.
Old 15th July 2013, 06:36 PM   #125
Right. So you could have changed ULGF by changing the capacitor's value as well as by degeneration of the input stage.
Don't forget that you need to do a bode plot of the miller loop as well as the global loop.
Ditto if you're sticking with TMC. I believe that with TMC one plot should look second-order and another should look first order. Both need to have decent stability margins.
Old 15th July 2013, 09:59 PM   #126
dadod is offline dadod  Croatia
dadod's Avatar
You can have it with one shot, just do a bode plot of the global loop and connect TMC resistor after the Tian probe.
Old 16th July 2013, 11:32 PM   #127
Struth is offline Struth  Canada
Banned
Hi Guys
This VAS is actually interesting!
Do you have a souped up Audio Precision system to measure a real product with? Are there measurements or just sims?
Have fun
Kevin O'Connor
Old 17th July 2013, 05:40 AM   #128
Nah I don't, but I can wish =) So far the measurements are just sims and the results are used as a guideline, not an absolute.
I've given my VAS a little break as I'm now at a point where I don't know well how to continue:
On one end, with a simple miller compensation from VAS-out to VAS-in of 56p, (and a small tweak to the buffer local feedback (82pf with 22Ohm series) I can get it rock stable. The THD is very bad this way; around 0.01%. When I take out the OPS and put back in an ideal OPS, the THD is back to 0.000055%.
It's clear that the OPS is the main contributor to THD and when excluded from the feedback, it rears its head bad.
If I use OPS inclusive feedback, I get this extra phase shift which leaves me with a phase margin of less than 30 degrees on two locations in the band. This is not acceptable.
So. I think I'm stuck. Using plain miller defeats the purpose of this VAS as I throw away all that loopgain.
I've tried TMC, TPC and variants, but no matter, where there is improvement in gain, there's a degradation in phase.
Old 17th July 2013, 07:29 AM   #129
That's what compensation does in all circuits! You have to get the loop gain to cross zero before all your high-frequency singularities kick in and bring their evil phase shift.
Old 17th July 2013, 08:24 AM   #130
haha yeah, I've experimented with this schematic like a mad-man. I think I made some improvements though. I now have a combination of both Cherry and TMC with the C/R path from VAS out to OPS out is rather low-ohmic.
The question though is what an acceptable phase margin is. When I assume the OPS series resistance (regardless of Cload) is at least 50mOhms, I can get so much more performance from the circuit than if I would stabilize it for an ideal C.
In this situation I now have around 0.000023% into 8Ohm and 0.000046% into 4Ohm. As long as the series resistance doesn't drop below 50mOhm it remains stable at all capacitances (within sensible range as they still load the OPS).
So what's practical?
My New VAS TopologyHide this!Advertise here!
Bob Cordell's Complementary IPS-VAS topology danny92 Solid State 32 2nd January 2016 06:11 PM
Differential VAS topology danny92 Solid State 13 11th June 2013 07:03 PM
Differential VAS topology Bob Cordell based danny92 Solid State 0 6th May 2013 05:41 AM
A superior VAS clamp and VAS current limit for the Blameless. GK Solid State 128 19th October 2011 04:03 PM
low VAS sealed better than high VAS? matos81 Subwoofers 3 7th April 2006 12:28 PM
