ODNF or no GNFB power amp - Page 10 - diyAudio
Old 30th July 2013, 09:25 PM   #91
MiiB is offline MiiB  Denmark
Why don't you look at the HEC or Cordells error correction. I do believe that most of what you're trying to cure is the poor performance of your output buffer. Some kind of feed forward Error correction could make your concept fly... What kind of performance do you have with high signal on the voltage gain stage alone.??
Old 31st July 2013, 04:49 AM   #92
dadod is offline dadod  Croatia
dadod's Avatar
I used HEC, look here ODNF or no GNFB power amp. Voltage gain has quite low distortion, main distortion is comming from output stage.
Old 3rd August 2013, 11:38 AM   #93
Ohh sorry I did not see that... What about Cordells feed forward error-correction, would that yield better results... Somehow it would be nice to get the opamp out, as in all the opamp-argumented feed back soldering I have done it's impossible to thame.
Old 3rd August 2013, 02:07 PM   #94
dadod's Avatar
What is different between HEC and Cordells feed forward error-correction. Could you direct me where to look in his book?
Old 26th November 2013, 09:17 AM   #95
cast is offline cast  China
Old 26th November 2013, 09:18 AM   #96
Old 26th November 2013, 09:18 AM   #97
Old 26th November 2013, 09:19 AM   #98
Basic question re: gNFB around 3 stages rongon Tubes / Valves 7 21st May 2012 03:52 PM
LED bias with gNFB mashaffer Tubes / Valves 1 21st December 2010 11:01 PM
Headphones amplifier with highish gnfb 00940 Tubes / Valves 9 12th October 2009 03:11 PM
Suitable jfet for an zero GNFB amp? roender Solid State 14 28th November 2008 04:08 PM
GNFB and distortion myhrrhleine Solid State 16 29th July 2008 05:55 PM
Copyright 1999-2017 diyAudio
