ODNF or no GNFB power amp
Old 28th June 2013, 02:55 PM   #31
Shinja is offline Shinja  Japan
@pawel
I found the lower side mosfet is Nch.
@dadad
this is the feedforward distortion cancellation based on 80's DENON's circuit, he wrote.
http://www.ne.jp/asahi/evo/amp/Dnfb/edc.htm
I reserched it ago and found a patent US4447790.
Old 28th June 2013, 03:11 PM   #32
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by Shinja View Post
@pawel
@dadad
Distortion removal circuit
Thanks Shinja I will take a look at that.
Old 28th June 2013, 04:19 PM   #33
padamiecki is offline padamiecki  Poland
@pawel
yes you are right again, this should be nmos too
this is cured circuit but not works as good as in post 27, the cancelation dost pot U3 not works... http://www.diyaudio.com/forums/solid...ml#post3542525
File Type: asc odnfb vlt source separ power suppl (1).asc (4.5 KB, 30 views)
regards, Pawel
Old 29th June 2013, 11:48 AM   #34
dadod's Avatar
Nobody commented my implementation of the HEC output stage, it's a bit different from Hawksford.
Distortion decrease at 1kHz is 42dB and at 20kHz is 25dB.
I simulated noise at full and at -40dB volume.
Next simulation is the gain.
As this amp is whitout GNFB output is not close enough to zero V, next step to add DC servo.
File Type: jpg GainWire-HEC-power-noise-maxvolume.jpg (209.1 KB, 329 views)
File Type: jpg GainWire-HEC-power-noise-volume-40dB.jpg (207.1 KB, 308 views)
Old 29th June 2013, 02:31 PM   #35
Dear Dadod
you know I like your designs very much and I am very impressed of their performance but I cannot compliment every post
regards, Pawel
Old 29th June 2013, 03:11 PM   #36
dadod's Avatar
Originally Posted by padamiecki View Post
Dear Dadod
No compliments, technical comments only.
Old 29th June 2013, 03:41 PM   #37
bogdan_borko is offline bogdan_borko  Serbia
bogdan_borko's Avatar
Dadod, that`s all nice in the simulation world but there`s a work ahead of you to therm. stabilize output stage and bias...
Svakog dana u svakom pogledu sve manje nazadujem.
Old 29th June 2013, 04:20 PM   #38
dadod's Avatar
Bogdan, yes there is more work to do. Q31 and Q32 should be thermaly connected with output transistors and P2 used for the bias adjustment. D1 and D2 should compensate for ambient change of temperature. Those days I am occupied with my grandsons and less time left for audio hobby.
Old 30th June 2013, 04:01 PM   #39
dadod's Avatar
Here is HEC OPS with DC servo. This amp is now DC from the input to the output.
P1 is a volume control and P2 bias adjustment. Max gain is 45 or 33dB and in this case there is no need for preamplifier at all, just input switch.
Old 30th June 2013, 04:04 PM   #40
mcd99 is offline mcd99  United Kingdom
Only thing I can add is that it is worth considering adding a low pass filter to the servo output. Another defence against high frequency nasties getting through the servo.
ODNF or no GNFB power ampHide this!Advertise here!
Basic question re: gNFB around 3 stages rongon Tubes / Valves 7 21st May 2012 03:52 PM
LED bias with gNFB mashaffer Tubes / Valves 1 21st December 2010 11:01 PM
Headphones amplifier with highish gnfb 00940 Tubes / Valves 9 12th October 2009 03:11 PM
Suitable jfet for an zero GNFB amp? roender Solid State 14 28th November 2008 04:08 PM
GNFB and distortion myhrrhleine Solid State 16 29th July 2008 05:55 PM
