Regulated Power Supply for LTP/VAS needed? - diyAudio
Old 20th June 2013, 06:54 PM   #1
danny92 is offline danny92  Portugal
Default Regulated Power Supply for LTP/VAS needed?
Hi everyone,
With this design I should use a regulated power supply for the LTP/VAS, because of low PSRR? Or that's not necessary, I've seen some designers, splitting the reference current resistor that connects to ground at the current sources and then connecting the middle point to a capacitor and this capacitor to Vcc or to ground, this increases the PSRR? Or the capacitor has other reasons for being used?
Thank you for your help,
Best regards,
Daniel Almeida
Old 20th June 2013, 08:59 PM   #2
The main reason to use a regulated supply on a MOSFET amp, is where the voltage is higher in order to get maximum drive capability out of the MOSFETs.
Old 20th June 2013, 09:18 PM   #3
nigelwright7557's Avatar
I use a 33r in series with the supply and a 470uf to ground after the 33r on my LPT/VAS stages.
I noticed that without this I was getting a bit of hum on the output.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 20th June 2013, 10:50 PM   #4
Right, thank you very much for your help
LTP to VAS interconnection. Dave Zan Solid State 7 6th February 2013 09:08 PM
Regulated Vs Non-regulated linear Power Supply mbeards Tubes / Valves 2 30th January 2013 10:45 PM
help needed for LTP pair transistor amp for single supply rrbadrike Parts 0 1st January 2013 09:24 AM
+-45vdc regulated power supply schematics needed. Maroof Power Supplies 49 2nd September 2012 08:30 PM
+/- 12v regulated power supply review needed renfrow Power Supplies 6 26th October 2008 11:35 AM
Copyright 1999-2017 diyAudio
