I need CD 4017 help
I need CD 4017 help
Old 20th June 2013, 03:58 PM   #1
east electronics is online now east electronics  Greece
east electronics's Avatar
Default I need CD 4017 help
I need help on a CD4017 circuit there is something that don't know how to do
Application is like that
CD 4017 triggered from a 555
1)4017 is on standby mode where port O is on and waiting
2)there is got to be some start button to start the sequence
3)4017 then will activate in sequence ports 1-7 with 2 seconds interval
and after finish the circle will have to go back to step 1 where port 0 is on and waiting .
What i don't know how to do is ""park" the 4017 to step 1 after the sequence
Kind regards
sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 20th June 2013, 04:23 PM   #2
There was some help from a friend explaining to me the use of pin 13 which is the clock inhibit which actually means that i can use the last port of the 4017 to stop the clock
then 4017 will park at last port on ( 9) then activating the clock again or disconnect pin 13 will start again the clock and 4017 will start the sequence all over again starting from port 0
Will try that and get back in between any other ideas are very welcome
Old 20th June 2013, 04:33 PM   #3
wg_ski is offline wg_ski  United States
The reset pin will set it back at zero. Connect it to the output that's one past where you want it to stop and re-cycle for sequences shorter than 10. Use that same signal to trigger a latch (flip flop will work) to the clock enable. That will stop the clock until manually reset.
My DJ light controllers are built around 4017's and 3914's - even the new one I just built this year. I love fooling with this old stuff.
Old 20th June 2013, 04:43 PM   #4
reset pin is set to ground ... this with the flip flop i don't understand how to do
problems :
1) The voltage coming out of a 4017 output is not enough to energize the inhibit pin 13 it needs probably to be driven from a transistor from rail voltage can be done
2) to start the sequence again you need to connect pin 13 to ground ...so a switch or a push button or a relay for a thing like that cannot be done since in the time pin 13 is in the air will go to any port randomly i think ...
Old 20th June 2013, 04:56 PM   #5
ok a BC 547 triggered from any port will stop the clock ordered by the specific port
Question is how do you start it again ? if you remove power from the transistor or disconnect anything 4017 picks up noise from the pin and jump to any or all ports on
Old 20th June 2013, 05:38 PM   #6
Connect all un-used inputs to GND thru a 10k resistor. Hit reset with +5 or whatever to send it back to 0. You can do that with the resistor connected.
Old 20th June 2013, 06:57 PM   #7
Οκ .... understood that pin 13 function will not help ...
In pin 15 i added an RC for a pull down function to ensure that start will always happen from port 0 at power up
In my case and externally from the 4017 relays will be driven and hold after ordered from any of the 6 ports of the 4017 now after relays are in hold mode it will not mater if the 4017 is still running
Then this is the stop mode and one and only push button that will interrupt the power will start the sequence all over again
I am done
Thanks ppl that was help!!
I need CD 4017 helpHide this!Advertise here!
supply regularly CD-Pro2 module VAU1254 CD-Pro (VAU1252) CD-Pro2 (VAU1254/11) vam1250 smartech Vendor's Bazaar 1 10th April 2011 11:02 AM
Could someone post a CDROM Controller schematic to DIY the CD ROM to be a CD player? fsclub Digital Source 11 18th December 2006 02:19 PM
AKAI CD 93 or CD 73 cd players are sought tuncay Swap Meet 1 11th December 2006 08:01 PM
CD Player vs. CD Transport using CD-PRO2 module tomchaoda Digital Source 27 22nd May 2004 09:29 AM
How do I use CD-Rom diy meridian 588 CD player and 800 reference CD/DVD player? jelou Digital Source 4 29th April 2004 04:48 AM
