250w 8ohm amplifier - Page 65 - diyAudio
Old 24th July 2014, 03:08 PM   #641
Why change a Member's name, when it is already unique?
Is that to deliberately confuse us?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 24th July 2014, 03:23 PM   #642
still4given's Avatar
He signs his name at the end of each of his posts.
"Have fun, Kevin O'Connor"
If you would make a little more effort to embrace the theme of the conversation rather than nit picking it would be more helpful.
Old 24th July 2014, 03:33 PM   #643
As I said, Struth is unique.
Kevin is not unique.
I looked back in vain and no Keven was visible, but that was to be expected since you had mentioned lack of replies.
If you had stated Struth I would not have needed to ask.
regards Andrew T.
Old 24th July 2014, 04:10 PM   #644
Hehe, never a dull moment !
Jan
Old 24th July 2014, 04:18 PM   #645
Oops, Keven instead of Kevin (Struth).
regards Andrew T.
Old 24th July 2014, 07:36 PM   #646
I have a question. I want to test the IPS and VAS to make sure they are working properly before I go any further. If I remove R29 and R30, short C6 and then tie the junction of R56/57 to the collector of Q7 can I power up and test the IPS/VAS? Is there anything else I will need to do?
Thanks, Terry
Old 24th July 2014, 08:17 PM   #647
Sorry, I forgot to attach the schematic.
Here it is.
Old 24th July 2014, 10:45 PM   #648
jkuetemann's Avatar
I think that would have the input and VAS operating on their own, sans output section.
---Jason Kuetemann---
Power is only granted to those willing to lower themselves enough to pick it up.
Old 24th July 2014, 11:24 PM   #649
Thanks Jason.
I haven't tried separating the IPS and OPS yet but I had some spare time today so I hooked up one of the boards and gave it a try. I'm testing through a variac and light bulb tester.
First thing I noticed is that it immediately starts off at about +24V offset but quickly starts dropping and passes the 0V point after about 5 seconds or so. It then gradually continues on to about -40mV which continues to rise as the amp warms up and settles at about -140mV offset. At this point I have about 19mV across a pair of the 0R33 output resistors. The is as low as I can dial it as the pot is maxed out. I checked most of the VR of most of the resistors and they are close to what I see in spice but just touching the junction of Q3B and Q5C causes the offset to jump around and the bias to double. Not sure what it going on there.
Looking closer at the schematic I see that there are two 820uf caps on the - rail and only one on the + rail. Could this explain the huge offset at turn on that gradually goes away? That would have to cause a huge turn on thump. Is there a need for both C9 and C14?
Man I wish Struth was here to answer some of this stuff.
Thanks, Terry
Old 24th July 2014, 11:37 PM   #650
jkuetemann's Avatar
Hehehe, just had a look to see... He still has the design for sale on his website! Blasphemy!
300-800W 8Ohm Sub Amplifier KostasTheGreat Solid State 24 29th June 2013 09:27 PM
8ohm resistor in series with 8ohm speakers for a 16ohm OT? Reidy- Tubes / Valves 8 11th January 2010 12:25 AM
Copyright 1999-2017 diyAudio
