Electrocompaniet AW-100DM
Old 6th December 2003, 10:28 AM   #1
ManUtd is offline ManUtd  Norway
ManUtd's Avatar
Default Electrocompaniet AW-100DM
Hi There,
Got an old version of AW-100DM from 1986.
One channel is defective and the other one has been repaired
with new transistors,diodes,electrolyts.
I now need to know the bias adjustment of this amp.
On working channel i can measure approx. 2mV DC across emittor
resistor in Outputstage.
Supply voltage for AW100 is +-42VDC for outputstage.
Picture shown is for AW65,but is almost same AW100 has more
outputtransistors.
Is 2mV a normal Bias voltage for this circuit?
Thanks for any helps.
ManUtd
Old 6th December 2003, 10:45 AM   #2
ManUtd's Avatar
To bad picture,sorry.
Old 6th December 2003, 11:50 AM   #3
Rambi is offline Rambi  Netherlands
Default Re: Electrocompaniet AW-100DM
If the emitter resistors are 0.2 ohm (I can barely determine that from the picture) then 2mV is about 10mA. In this kind of circuit I would expect something like 100mA (20mV).
I don't know/have this amplifier, so maybe someone else (who does) can confirm this?
Remco
Old 6th December 2003, 12:33 PM   #4
ManUtd's Avatar
Thanks for your reply.
Yes,unfortunately picture is of bad quality.
Resistors are 0,2R and 3watt +-5%
When it is cold i measure 0,5mV and when it gets
hot i measure about 2mV.
This is measured on the one that is working and gets "normal hot" after
some 1/2 - 1 hour usage.
ManUtd.
Old 2nd January 2004, 04:19 PM   #5
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
ManUtd, do you have a better picture?
If so can you send it at andrea.pirovano@libero.it ?
Thank you
Andrea
Old 3rd January 2004, 01:19 AM   #6
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Default Re: Re: Electrocompaniet AW-100DM
Remco
I too would expect the 100 mA / device number after
warmup, which is about 20 mV across .2 ohm.
Old 30th October 2008, 02:21 PM   #7
Beachmountain is offline Beachmountain  Sweden
Thank You, ManUtd!
I have an amp just like that where the left channel is frying bacon at me. It works fine for a few minutes, then it starts to misbehave.
This will definitely make it easier to find the fault.
Anyone with suggestions as to what might be wrong?
I have just recapped the whole thing, and the rying remains, so I suspect one or more of tge active components.
On the other hand am I no electronics wiz :-).
Regards/Beachmountain
Old 30th October 2008, 11:40 PM   #8
homemodder is offline homemodder  Portugal
What amp do you have??? Im not so sure the amp in the first post is a electrocompaniet, never seen a schematic of that company that even resembles that one.
Old 31st October 2008, 12:39 PM   #9
ManUtd's Avatar
Smile Schematis
I got the copy directly from E.C so it is deftinately a original.
Old 31st October 2008, 12:44 PM   #10
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
And identical to the schematic of the Audiowire 65 that Mr Pairo used to have on his homepage.
The Norwegians seemed to have a thing for fast NEC output devices.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Electrocompaniet AW-100DMHide this!Advertise here!
Electrocompaniet Help Andypairo Solid State 72 3rd December 2015 03:25 PM
Hello from an Electrocompaniet Fan PrimeCase Introductions 10 25th September 2012 01:17 PM
Electrocompaniet AW 250 AMP. hogue Solid State 1 1st March 2004 05:48 AM
Electrocompaniet AW-100DM ManUtd Solid State 0 24th September 2003 08:27 AM
