how to manage psu for the car amplifier? with 5200 1943? - diyAudio
Old 14th June 2013, 01:38 AM   #1
Default how to manage psu for the car amplifier? with 5200 1943?
I want to build a car amplifier and was stuck at the power supply where the supply is just 12v so how to make a psu for a car amplifier where I would be using lme49810 and 5200 1943 pair...
Old 14th June 2013, 02:13 AM   #2
Look at any commercial car power amp. - They all use switchmode power supplies if they deliver more than about 15W RMS. 'Sounds good but switchmode is not the sort of PSU you jump into designing and building without considerable experience. Audio is a piece of cake compared to efficient, reliable (and safe) switchmode supplies.
The better solution is to use appropriate prebuilt 12V supply SMPS units of either single or dual polarity to suit your amplifier design. There are thousands of products and suppliers of these all over the net and Ebay.
https://en.wikipedia.org/wiki/Switch...e_power_supply
Ian
Old 14th June 2013, 02:47 AM   #3
Thank you Ian...
Old 16th June 2013, 08:33 AM   #4
Holgi is offline Holgi  Germany
Holgi's Avatar
It's not that simple if you're thinking of designing an SMPS for a car amp by yourself - at least having no experience. Not only that a car is a desaster in terms of EMC - which means you have to do careful filtering - but also you have to consider a highly dynamic supply voltage. In normal operation (engine running, bat ok) you face ~14VDC, but it can easily go up to 16-17VDC or down to 7V (ISO start-cycle or in engine start-stopp-mode). You would need at least a boost+inverter design but you have to deal with enormous current.
I would double the recommendation to go for a SMPS that is readily available and designed, built and tested for automotive use. In fact, I would never consider to build a high power car amp on my own, though I'm into DIY audio and I know vehicle electrics very well
BR,
Holgi
Edit: take a look at Rod Elliot's design, a nice introduction to car SMPS.
Old 16th June 2013, 10:29 AM   #5
for smps i think i need to go to a professional designer as I just wanted to know how its achieved and thank you very much for the link on Rod Elliot design
how to match the Transistors like toshiba 5200 1943 rhythmsandy Solid State 3 26th February 2016 05:06 PM
HIFI 700W Subwoofer Mono Amplifier Board By 10 Pairs 1943/5200 Amp Board For Subwoofe nelnar Solid State 2 21st July 2014 06:35 PM
PC PSU To Power Car Amplifier IXLoiero95XI Power Supplies 23 26th May 2014 03:42 PM
does a single pair of 5200 1943 total 2 needs matching? rhythmsandy Solid State 4 9th March 2013 06:07 PM
LME49810+5200/1943 better than opa549 rhythmsandy Chip Amps 0 5th December 2012 08:39 AM
Copyright 1999-2017 diyAudio
