FA607 questions
Hey all,
Wondering if I could get some help figuring out how to finish up the wiring for the kit I've been working on. I have a few questions.
1. I have a 10k Ohm audio pot that I was planning to use as a volume control thats rated for .25 watts. Can I use this pot when the amp circuit outputs 15 watts at 4 ohms?
2. I also have a switch to control power on/off that was not included with the kit so I need some advice as to where/how to wire the switch in the circuit.
Thanks for the help!
Heres a pic of the switch im using if that helps. It has two prongs but no indication as to where to wire each one
