Onkyo amp woes!
Onkyo amp woes!
Old 11th June 2013, 10:34 AM   #1
Charlie111 is offline Charlie111
Default Onkyo amp woes!
Hi folks I am really struggling with an Onkyo amp for which I cannot find a scematic, it is an itegra A-819. Some of the driver trannys are dead in the left channel can I replace 2sc2238's a968's & 2sc1940's & A915's with all 2sd1138's & 2sb861's, I should imagine gain is surely not a problem! The other channel I am having trouble with the bias, I am measuring zero across the emitter resistors (0V on output with healthy main power supply, and healthy 22v secondary supply to opamp) and when injecting a sine wave this is appearing as a saw tooth on the output :-( I have not come across this particular diff amp and current source configuration before, not to mention the active bias and cannot find any obviously faulty components! Any help would be appreciated! Thanks.
Old 11th June 2013, 04:41 PM   #2
east electronics is offline east electronics  Greece
east electronics's Avatar
Measure if there is proper supply in the drivers ..often drivers are powered after fusible resistors in the area of 10 ohm or so if one of them is blown you get no drive no bias ...
also look at the obvious poor soldering , broken traces , and open resistors ...
In between i will take a look for a schematic also
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 12th June 2013, 02:15 PM   #3
Hi Sakis thanks for the reply, supply to the drivers is fine as far as I can see, and there are no fusible / out of range resistors :-( The OPamp, part of the servo bias seems to be outputing 2.5V with zero on the output which I would not expect though!?
Old 16th June 2013, 08:09 PM   #4
hi folks I have stuck this to one side at the moment, but if anyone could give me any pointers, or help with a diagram I would be quite grateful :-)
Onkyo amp woes!Hide this!Advertise here!
Amp woes... Denon POA2400. mortron Solid State 12 15th April 2013 04:29 AM
Amp woes... Denon POA2400. mortron Solid State 0 11th April 2013 04:52 PM
Nad S100 pre-amp woes timpy Analog Line Level 3 19th November 2009 11:27 PM
Usher pre-amp woes... Illusus Solid State 15 25th September 2004 02:04 AM
Pre-amp woes mluckey Solid State 1 31st October 2003 07:20 PM
