Leach Superamp, round 2 - Page 18 - diyAudio
Old 1st July 2013, 08:11 PM   #171
amptech is offline amptech  Scotland
Send a message via MSN to amptech
Is your scope set to 20v max volt/div..
Old 2nd July 2013, 01:33 AM   #172
still4given's Avatar
I don't know. I have all the switches all the way to the top.
This picture is basically how it was set except it was set to chop and of course the Volts/Div and Time/div were maybe a little different. I was using it to work on a pre-amp today so those got moved.
Old 2nd July 2013, 04:27 AM   #173
Your scope settings...
CH1 is set at 1V/div
CH2 is also set at 1V/div but it is now in uncalibrated mode. Turn the red knob clockwise to the click end and the UNCAL indicator on its right should go off.
Same is the case with sweep setting. The knob on the right that sets the time/div has a red knob. Turn it clockwise to the click position and the UNCAL indicator on its left will go off.
Gajanan Phadte
Old 2nd July 2013, 08:56 AM   #174
Hi Terry, looking at post number 167 your meter's appear to be giving different readings with one under 4 ac volts and the other 86v... If the amplifier was giving such high o/p your jbl's would be cooked at that power. your need a heavy duty test load to check power out put of amplifier.
regards A.
Old 2nd July 2013, 12:30 PM   #175
regards A.
Mabe I wasn't clear. I didn't have anything hooked up to the output except for the scope and DVM. The meter on the left is hooked up to the input with the sine generator and the meter on the right is hooked up to the speaker jack. I do have a dummy load coming should be here any day. Once I have it I will run the test again
Old 2nd July 2013, 01:53 PM   #176
Gajanan Phadte
Hi Gajanan,
Thanks for the info. I have had no instruction in using a scope aside from what I have picked up here from little things like this. I should probably look up some tutorials or something. I was using the little red nobs to adjust the height of the wave to try and fit both waves on the screen. I didn't know they should be locked. This is probably a better picture of how it was set when I was testing the leach but I'm not sure it is clear enough to see any of the settings.
Thanks again
Old 3rd July 2013, 02:19 AM   #177
The ghost is back. It is a very puzzling thing. I had the amp playing all morning without a hitch. When the mail came my 300w, 8R resistor was in it so I was pretty excited about hooking it up to do some tests. Well I checked the right channel with the resistor hooked up to the outlet and I used a preamp so I could get a higher voltage on the input. I was able to get 59VAC on the output before it clipped. That was with 2.7VAC on the input. I then went about hooking up the left channel but when I powered it up it blew the fuse on the +rail. I figured I might have shorted the output while hooking everything up so I replaced the fuse and fired it up again. I checked all the voltages and everything looked good so I hooked up the input and began running up the sine wave. When I get to about 20Vac on the output is see the clipping start again. I can't believe my eyes. To test, I disconnect the dummy load and the clipping goes away. I reconnect and it's back. So recheck all the voltages and all looks right. If I run it up without a load everything looks fine. Another weird thing was I connected the speaker once and It went all the way to 59VAC on the output without clipping. So I rehook the dummy load and it clips again. However when I tried hooking up the speaker again it clipped this time. The other thing is that the heatsink got really hot. I though maybe the bias has changed so I rechecked that but it was good.
Any ideas? Any suggestions why it is only clipping on the bottom side of the sinewave?
Thanks, Terry
Old 3rd July 2013, 02:32 AM   #178
jkuetemann's Avatar
Looks like oscillation, not clipping. That also explains the extra heat and blowing of fuses. Something is definitely amiss and causing a stability issue.
---Jason Kuetemann---
Power is only granted to those willing to lower themselves enough to pick it up.
Old 3rd July 2013, 03:56 AM   #179
I misspoke earlier. the 59VAC was with no load. It was only 47VAC with the load attached.
So you think the oscillation could be caused by Q1-Q4 not being matched. I have been meaning to change those out. I will do that and see how it goes.
Old 3rd July 2013, 04:04 AM   #180
OK, based on the formula in post #170 I have 47V/8R = 5.875 * 47V = 276W
That is pretty close to what the Superamp is rated for.
Leach Superamp Discopete Solid State 1 13th December 2009 06:58 AM
Leach Superamp Discopete Solid State 0 12th December 2009 06:01 PM
Leach Superamp problems still4given Solid State 29 23rd September 2006 07:38 AM
Leach SuperAmp acenovelty Solid State 67 31st March 2006 01:10 AM
Leach superamp Opie Solid State 6 1st March 2002 04:29 AM
Copyright 1999-2017 diyAudio
