60-100W Mono Class AB diy AMPS - diyAudio
Old 8th June 2013, 07:58 AM   #1
kinku is offline kinku  United States
Default 60-100W Mono Class AB diy AMPS
I am planning on starting a project for multi channel hi fidelity system and need 6 Amplifier blocks power rated somewhere between 60-100W working in CLASS AB.Two of them i like it in CLASS A.
I know there are many options and when it comes to quality it is difficult to reach conclusions.
I have four Signal transformers A41-130 with me left over from an old project, so planning to use them as power supply for 4 channels(14/28,130VA).
Pre assembled KITS with good quality components are being considered.
Awaiting suggestions.
Old 8th June 2013, 12:45 PM   #2
how are you going to get 60-100W out of 28V CT transformer? +/-19VDC. wish will drop to 17-18VDC under hard load. you are lucky to get 13W at 8ohm.
Old 8th June 2013, 12:54 PM   #3
I was thinking if used 0/28 V configuration it may work,rather than 14-0-14. Again it is just a possibility in case a monoblock board is available.I am not planning to make my plans centered around a transformer.
Old 8th June 2013, 12:57 PM   #4
okei. i would get some good transformers. 2*30V transformers.
you say multi channal. is it active stereo, or surround?
Old 8th June 2013, 01:11 PM   #5
I am planning to use in active 3 way system,of which I like to use a Class A AMP for midrange.Which should be ok with a power rating of 50-60W or even lower.
Class AB for others. Trying to limit my total power to 200W RMS per Stereo channel( divided between 3 speakers)Can not think of a reason,why I should waste power.
I thought about getting Brystons for 6 channels but then realized it would be an overkill in terms of power usage.But I am expecting something that matches the quality of Bryston in lower rated power.
Old 8th June 2013, 01:19 PM   #6
djoffe is offline djoffe  United States
for the class AB stuff, check out
Akitika GT-101 Audio Power Amplifier Kit
the amp modules and heatsinks, and other bits are also available separately...
Akitika Store
just scroll down the page a bit...
Old 8th June 2013, 01:29 PM   #7
lanchile's Avatar
Thumbs up Bryston amps
Bryston amps are very, very good! They are build like tanks and will last forever. no wonder their warranty is 20 years. Right now there are some very good (mint) condition Bryston 4B amps in eBay for around $1500 USD. I had a Bryston B60 that I loved very much. You can not go wrong with Bryston amps
Make it simple...Make it better!
Old 8th June 2013, 01:37 PM   #8
I know they are good,but I need about 6 Channels and two of them need to be Class A IF POSSIBLE.and also I do not need that much power per channel.
Old 8th June 2013, 01:48 PM   #9
lanchile's Avatar
Well. Do you want to build them or buy them?
Old 8th June 2013, 01:53 PM   #10
I am considering building them from a KIT ,if the KIT components are of good quality, I can get the assembled too. So looking for some suggestions and experiences. Enclosures are going to be an issue for such configurations I guess( 6 chanels) .I would consider lucky if I can finish 3 units in one enclosure.
I tried the ebay MX50 DIY Kit, Class AB 100W+100W; Worked but problem. Buckeye Solid State 80 22nd March 2017 07:15 PM
100w to 1000w class ab wattaniya Solid State 87 23rd January 2017 11:00 PM
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 75 3rd December 2016 06:49 AM
2 ohm with 100W class AB or D amplifier Hadighorbani Solid State 23 7th June 2012 09:05 PM
Cannibalize a Class AB Stereo to Class A Mono block. owenhamburg Solid State 8 13th September 2010 08:55 PM
Copyright 1999-2017 diyAudio
