phase issues when using a .01uf in parallel with the input capacitors?
Old 7th June 2013, 06:29 PM   #1
rhythmsandy is offline rhythmsandy
Default phase issues when using a .01uf in parallel with the input capacitors?
I tried to use a .01uf/100VDC polystyrene capacitor at the input as bypass capacitor for the 2.2uf cap and i found a decent hf clarity but it seemed like some phase issue and sounded muffled in the midrange. Does it has any effect on the phase?
Old 7th June 2013, 06:43 PM   #2
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
No.
Frank
Old 7th June 2013, 06:45 PM   #3
so is it good to have small cap as low as .01uf and 18pf bypass at the input?
Old 7th June 2013, 07:12 PM   #4
jjrenman is offline jjrenman  United States
Did you use a higher quality bypass cap? IME, often the sound character shifts to whatever the bypass is.
Old 7th June 2013, 07:38 PM   #5
Those additional caps will make absolutely no difference.
Frank
Old 7th June 2013, 07:46 PM   #6
Conrad Hoffman is offline Conrad Hoffman  United States
The major factor is dissipation factor, but most inputs will have a series resistance that swamps it out completely. Shouldn't matter. It shouldn't be audible unless the other cap has astoundingly bad response or something. Input of what?
I may be barking up the wrong tree, but at least I'm barking!
Old 7th June 2013, 07:50 PM   #7
jcx is offline jcx  United States
try Audio DiffMaker
Old 7th June 2013, 07:51 PM   #8
So the OP is just hearing things?
Old 8th June 2013, 02:55 AM   #9
there is difference in the HF can clearly hear the difference...
Old 8th June 2013, 03:02 AM   #10
I think this is happening because of the inductance of the 2.2uf cap as there would be inductive winding and once we use a small cap it might be passing the hf info more from the smaller cap and hence making it a bit difference in hf..
phase issues when using a .01uf in parallel with the input capacitors?Hide this!Advertise here!
Speaker phase issues. argonrepublic Multi-Way 2 30th September 2011 07:17 PM
T-amps phase issues (????) Phobos Class D 2 5th June 2007 07:34 PM
phase issues with mounting 2 ribbon drivers next to each other? thadman Planars & Exotics 9 31st July 2006 05:46 AM
used 0.01uF CRC teflon capacitors serengetiplains Swap Meet 11 23rd May 2004 04:07 PM
.01UF 50 volt glass capacitors KevinLee Swap Meet 0 15th December 2003 05:48 PM
Copyright ©1999-2017 diyAudio
