What can i made from 2x55VAC 1000W toroidal transformer ?
Any transformer under no load will give more than the advertised secondaries voltage. Under a very big load that voltage will drop , sometimes more than the advertised voltage. But after rectifying the dc voltage will be around 1.4x the secundaries voltage, regardless of the load.
Am I wrong?
Am I wrong?
Wow, a 180 degree change using the edit button. Well done.
55VAC @ 1000VA is the transformer rating. It has to deliver this or it is in default of its specification.
What you are arguing about is called regulation. 40% would be terrible for transformer regulation.
the point is: 2x55Vac sec transformer will give you around 375W average at 8ohm.
55x1.41=77.5Vdc rails. 77.5x0.707=54.8Vrms. 54.8x54.8/8=375W average at 8ohm and not 180W.
however. this is a teoretical ideal world. in the real world there will be some voltage loss. how much depends on the amp.
That's 60% true. But the transistors eat power too for the heat sink. I have an 150W amp that dissipates 50W into the heat sink.
heat disipation got nothing to do with it. that do not change any voltage sving. it's the same calculation if its class A class A/B or class D or what ever.
the heat disipation is the result of consumed current at the given voltage by the outputs. and there is ofcourse a couple of volts lost in the outputs too.
i have a 25W amp that dissipates 125W at the heatsink at idle for each ch. but still, +/-24V rails still gives me 25W average at 8ohm.
The 40% "lost" refers to the heat dissipation from the transistors not the transformer.
Why are you are you arguing? You are still wrong.
55VAC -> 55Vrms@1000W -> 55Vrails -> 55V/sqrt(2) = 38Vrms -> sqr(38V)/8ohm=180Watt rms
This calculation is simply wrong. If the transformer is rated for 55VAC at 1000VA then the rails can be +/- 76VDC. The output can be 54Vrms - active device headroom required, not 38Vrms. Don't ******** that you accounted for real world losses, those don't magically equate to sqrt(2).
nothing wrong with any 4year old Thread.
The rectifier passes the peak of the sinewave to the smoothing capacitors.
A dual 55Vac 1kVA transformer could have a peak voltage of around 124Vac on the bridge rectifier. That would give ~ 175Vdc across the two smoothing capacitors, i.e. +-87Vdc
