What can i made from 2x55VAC 1000W toroidal transformer ?
Old 14th November 2017, 07:20 PM   #31
asuslover is online now asuslover  Romania
That's right.
I used edit again. No reason to argue here.
Old 14th November 2017, 07:26 PM   #32
diyralf is offline diyralf
diyralf's Avatar
Originally Posted by AudioSan View Post
the point is: 2x55Vac sec transformer will give you around 375W average at 8ohm.
55x1.41=77.5Vdc rails. 77.5x0.707=54.8Vrms. 54.8x54.8/8=375W average at 8ohm and not 180W.
however. this is a teoretical ideal world. in the real world there will be some voltage loss. how much depends on the amp.
That's 60% true. But the transistors eat power too for the heat sink. I have an 150W amp that dissipates 50W into the heat sink.
Old 14th November 2017, 07:36 PM   #33
AudioSan is offline AudioSan  Norway
heat disipation got nothing to do with it. that do not change any voltage sving. it's the same calculation if its class A class A/B or class D or what ever.
the heat disipation is the result of consumed current at the given voltage by the outputs. and there is ofcourse a couple of volts lost in the outputs too.
i have a 25W amp that dissipates 125W at the heatsink at idle for each ch. but still, +/-24V rails still gives me 25W average at 8ohm.
Old 14th November 2017, 07:36 PM   #34
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Originally Posted by diyralf View Post
The 40% "lost" refers to the heat dissipation from the transistors not the transformer.
Why are you are you arguing? You are still wrong.
55VAC -> 55Vrms@1000W -> 55Vrails -> 55V/sqrt(2) = 38Vrms -> sqr(38V)/8ohm=180Watt rms
This calculation is simply wrong. If the transformer is rated for 55VAC at 1000VA then the rails can be +/- 76VDC. The output can be 54Vrms - active device headroom required, not 38Vrms. Don't ******** that you accounted for real world losses, those don't magically equate to sqrt(2).
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of Totò? Umberto Eco
Old 15th November 2017, 09:33 AM   #35
diyralf's Avatar
With 1000W load, your headroom is 54V. That means 54Vp for output. 54Vp means 38Vrms. Don't mix up peak and rms.
Old 15th November 2017, 10:37 AM   #36
like you do? its not 54V peak. peak voltage would be around 77V
Old 15th November 2017, 12:20 PM   #37
R.I.P.
nothing wrong with any 4year old Thread.
The rectifier passes the peak of the sinewave to the smoothing capacitors.
A dual 55Vac 1kVA transformer could have a peak voltage of around 124Vac on the bridge rectifier. That would give ~ 175Vdc across the two smoothing capacitors, i.e. +-87Vdc
regards Andrew T.
What can i made from 2x55VAC 1000W toroidal transformer ?Hide this!Advertise here!
transformer rating for a 1000W rms amp sekhar Power Supplies 5 11th July 2010 11:25 PM
Anyone know where I can get a single custom toroidal made? SQLGuy Solid State 13 31st December 2009 06:41 PM
Toroidal transformer Ghianni Power Supplies 8 15th November 2006 04:44 PM
WTS. Toriod 2x55VAC / 500W Jan Dupont Swap Meet 0 19th October 2005 08:05 PM
