Old 3rd June 2013, 07:37 PM   #1
raul_77 is online now raul_77  Spain
Default Schemes of no-feedback amps
Please, if anyone has any scheme of amplifiers or preamps without feedback, preferably solid state, Can you put here?
Almost 100% of the schemes that can be achieved using feedback, but I'am more interested in designs without feedback.
I mean global feedback, may have some local feedback.
Anticipated thanks.
Old 3rd June 2013, 09:21 PM   #2
dadod is offline dadod  Croatia
dadod's Avatar
Anticipated thanks.
Preamp here No NFB line amp (GainWire mk2) and here Current conveyor as a voltage amplifier
Old 3rd June 2013, 11:10 PM   #3
akis is offline akis  United Kingdom
I have designed a built an amp where the current amp stage (final stage) uses no global feedback, and the driver (voltage amp) stage has no sense of the output. Does that count?
Old 3rd June 2013, 11:36 PM   #4
Hi dadod, very interesting, many thanks!
Hi akis, yes! Can you share your design? Please.
Happy days
Old 4th June 2013, 05:40 AM   #5
great Krill: Krill - The little amp that might...
and http://www.diyaudio.ru/filestore/Mil...-_cookbook.pdf
regards, Pawel
Old 4th June 2013, 07:11 AM   #6
knutn is offline knutn  Norway
Voltage Amplifier & Current Buffer DIY
Old 4th June 2013, 10:34 AM   #7
forr is offline forr  France
forr's Avatar
post #4 dadod : there is no amp without any negative feedback.
Cant' we say : there is no amplifying device without negative feedback, even it has no degenerative resistor in its following electrode ?
I think that Bob Cordell, speaking about local negative feedback, tells something like that degenerative resistors has about the same effects on high compoments of harmonic distorsion as global negative feedback.
Old 4th June 2013, 10:49 AM   #8
dadod's Avatar
You are right!
Old 4th June 2013, 11:36 AM   #9
Anticipated thanks.
Hello, Raul
This is a very good sounding unity-gain NoGNFB preamp (buffer).
Input impedance 50kOhms, output impedance 6 Ohms. THD is a bit compensated by counter-polarity jfet-bjt stages, but not THD is the main ground for good sound. Output zero voltage (quite stable) is adjusted by corresponding paralleling of R2 resistor.
Greetings to Spain, I was working for some period at the University of Alicante.
Vladimir
Old 4th June 2013, 04:08 PM   #10
00940 is offline 00940  Belgium
This started as a low gnfb headphones amp (by Kevin Gilmore, see this ), morphed into a high impedance balanced to unbalanced converter (as suggested by jcx) and turned into a decent preamp (by lazyness, never bothered to turn it back to its original state).
Sims in ltspice give 0.02% thd for 2vrms into 600r. It could be improved a lot with cfp at the input.
Ben.
Integrated audio amps without feedback akis Solid State 1 11th May 2010 02:37 PM
Looking for feedback on Bottlehead amps agweeks Tubes / Valves 24 4th August 2008 07:01 PM
Application of feedback Quad amps Chris Daly Solid State 0 12th August 2005 02:08 AM
Feedback in IT coupled amps? Fuling Tubes / Valves 0 23rd February 2005 02:11 PM
Alternative modulation schemes for class d amps Nirav Desai Class D 6 10th January 2005 09:26 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
