Hi, I need a low power, power amp for my system (2way with active crossover). I had toyed with the idea of a Pass F5 or a JLH, but they seem over the top since I only need 1 Watt, and I need 4 channels. I came up with this as an alternative. There's no power amp as such, just a class A, unity gain current buffer for the pre-amp. The feedback can be removed from the pre-amp and put on the end of the buffer to get low distortion, or left where it is and have no feedback.
I think of it as a JLH with the middle transistor upside-down, and imagine (no sim software or test equipment at the moment), that the top transistor works as an emitter follower with an active load formed by the bottom transistor (one of the definitions of the JLH). Is this likely to work? Thanks, Brian. |
#2 |
The idea is valid, the challenge (as Messrs Hood and Pass have pointed out) is getting a current source with the bandwidth (slew rate) you need.
If you really want to get simple then some PA iron working as an inductor in series (like capacitors in parallel) with some large air core inductors should do well. Then you "just" need to sort out the bias settings. Frankly a single FET (a la Nelson Pass) with a large inductor and an "ultra path" DC blocking cap would be the easiest solution. Back to a single device outside your op-amp. If brave, the capacitor is optional with split rails (if you can use the op-amp as a DC servo. |
#3 |
bad ascii art follows
#4 |
Hi thoglette, thanks for your reply and suggestions. I can see how an output FET would work open loop, but to work closed loop, would it have to be a source follower?
I think my original idea would be more linear assuming I can sort the current source out as you say. The simple answer to that is to bootstrap it as JLH did, but I would probably try a normal two transistor circuit first. I think I need to get a PC the I can simulate this. Best regards, Brian |
#5 | |
Should work well, just a little more complicated. 1W into 8ohms is 350mA, if you can find a high beta bipolar you may be able to avoid the voltage amp stage |
#6 |
Why reinvent the wheel - the JLH can be made to work at lower power and you can use smaller transistors for the output. THe basic JLH is simple enough and is a proven design. Scaling it down shouldn't be an issue - in fact I think it's been done before for use as a headphone amplifier.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#7 | |
Best Regards, Brian |
#8 |
Hi Guys
The JLH structure is riddled with THD and bias problems. Best to avoid it unless you really like rising THD with level. Scaling the circuit up or down simply moves the cusp of muddiness to higher or lower power and SPL levels. The easiest way to convert the opamp preamp into a power amp is to add a complimentary follower stage - either as CFPs or EFs. Make sure there is a small resistance between the opamp output and EF input, with a local feedback cap around the opamp for stability. Biasing is achieved using a standard bias regulator (Vbe multiplier base spreader). This can be fed by actual current sources or bootstrapped resistors. No one has mentioned that the power supply in the preamp will not support the current needed to drive a speaker even to 1W per channel. That level requires about 350mA per channel into 8R, at which point the output stage is dissipating around 5W peak assuming +/-15V rails. So, good heat sinking is required, as well. TO220 F-paks like the 2SC4793 - 2SA1837 pair allow currents up to about 1A and do not need mica insulators - just bolt them to a heat sink. Parallel pairs would help with peak output power up to 1A5 loads. Larger packages (TO-3P, TO-246) provide lower thermal resistance and safer operation at typical listening levels. These do not need paralleling to handle the current, although there are benefits to paralleling as explained in my books, and others, as well as on various threads here. Given that true listening room SPLs that are tolerable - let alone listenable for hours - are much lower than most people suppose, being able to get a watt or two per speaker is sufficient and does not require high supply voltages. This applies easily to pop music and to movie and TV sound. If you listen to classical music - especially exclusively - then much higher peak power is beneficial as the dynamic range is higher on average - 20db typical. The above circuit will essentially look like many headphone drivers, based on the classic opamp with discrete current booster. There is a certain amount of complexity that proper design requires. It is overlooked by everyone that the historic designs of JLH and others, particularly UK designers, was predicated on keeping cost low as BJTs were "expensive" at the time. This frugality lead to many assumptions about circuits being spouted and repeated to the point of being believed as unthwartable. In the proper context, those old rules fall to pieces and those old circuits are best forgotten, except for being steeping stones to truly great performance. Have fun Kevin O'Connor Last edited by Struth; 6th June 2013 at 03:36 PM. |
#9 |
yes !
#10 |
Hi Kevin, thanks for the conprehensive reply. I'm not sure what benefit a follower stage would offer over what I have posted since my idea is a follower anyway, could you please clarify a little. I have no PC or simulation tools at the moment, so I cannot check different topologies.
I shouldn't really of mentioned JLH because my middle transistor is "up side down", and is an emitter follower. Best Regards, Brian |
| adding current limiting to a power supply | dietnews | Power Supplies | 78 | 3rd March 2013 09:08 PM |
| Low wattage power amp for preamp. | unklejman | Instruments and Amps | 10 | 28th February 2013 03:44 PM |
| adding a preamp to tube power amp | drgroove | Tubes / Valves | 13 | 29th July 2012 11:32 PM |
| preamp supply LOW power LOW noise LOW cost | drdagor | Power Supplies | 1 | 13th September 2010 11:39 PM |
| Nuuk's buffer's current draw (and power supply) | dsavitsk | Chip Amps | 0 | 16th April 2005 10:04 PM |
