I need help with mosfet circuit
Old 1st June 2013, 04:19 PM   #1
rafjr00 is offline rafjr00  United States
Default I need help with mosfet circuit
This is not a Pass design but I need help and this is THE place for mosfet.
I was given a MosFet 120, Dyna st-120 modded amp. It was designed and built by Frank Van Alstine. I contacted him at AC but this is one of his very early ones and he does not have anything on it.
I have all the pieces, according to the parts list, except for the PCBs.
Alex mm has been kind enough to offer his services in design new ones but has questions about the schematic as some things are not marked.
I can not express how thankful I would be if some of you would look over the schematic and offer your two cents.
Thank you,
Riki
Parts list
Schematic
Old 2nd June 2013, 11:57 AM   #2
How about moving this to solid state?
His "mosFET" excuse is not a valid reason to post in the Pass section.
regards Andrew T.
Old 2nd June 2013, 12:13 PM   #3
Mooly's Avatar
Moved to solid state forum.
Old 2nd June 2013, 04:38 PM   #4
No excuse Andrew,
Thanks for putting it in the right place.
Old 2nd June 2013, 04:45 PM   #5
I have waited for more than two minutes and image is not downloading.
The download is still waiting while I type this.
regards Andrew T.
Old 2nd June 2013, 07:01 PM   #6
jaycee is offline jaycee  United Kingdom
There wasn't much missing. Here's my best guess. I left out the regulator part as that's fairly obvious.
Old 2nd June 2013, 10:03 PM   #7
Not sure Andrew, just worked for me. :-(
Thanks Jaycee
Alex is working on the PCB layout for me.
Due either of you see anything out of place/not right/could be better?
Old 3rd June 2013, 01:40 AM   #8
I'd probably use a larger input cap C6, at least 1uF.
I think those gate resistors R11 and R12 are too large.
Add gate protection to the MOSFETS
Do away with the 1N914's - use LEDs perhaps.
I'm no expert with MOSEFTs though to be honest. Is there any reason for making this particular circuit?
Old 3rd June 2013, 02:42 AM   #9
I just wanted to put the amp back together, but I am not a stickier for keeping it true to the schematic.
Should I start with the same number of LEDs as 914s?
Old 3rd June 2013, 08:26 AM   #10
No, the 1N914 drops 1V, a red LED is about 1.7V, green typically 2V. I'm wondering why they didnt use a 5.1V zener instead of all those diodes - noise perhaps.
I can't find anything about Q2 except that it was a small MOSFET.... otherwise i'd try and simulate the circuit
I need help with mosfet circuitHide this!Advertise here!
Class Mosfet power amplifier circuit Agus Widarto Pass Labs 16 18th February 2008 04:06 PM
bias circuit for mosfet help AudioGeek Solid State 2 29th April 2006 11:22 PM
Will this MOSFET-driver circuit work? Danko Power Supplies 7 24th June 2005 02:09 PM
short-circuit protection in mosfet's amp...?? csl113 Solid State 8 31st January 2005 06:10 PM
MOSFET equivalent circuit nobody special Solid State 1 13th February 2003 06:12 PM
Copyright ©1999-2017 diyAudio
