Trying to add pre-out/main in CA-410 Yamaha - diyAudio
Old 29th May 2013, 04:44 PM   #1
Default Trying to add pre-out/main in CA-410 Yamaha
Hello all,
This is my first post on diyAudio. The national forums did not give enough info. Well they did, but not regarding my question. I've managed to replace the PSU capacitors & repairing the Watt meter lights using led's. The pics:
https://plus.google.com/u/0/photos/1...77410188427537
I've studied the schematics a dozen of times. I understand after 4 months of studying (back to physics!) the basics again. About transistors/caps/polarisation etc.) So far for the intro.
I've read this topic on diyAudio:
Trying to add pre out/main in to integrated amplifier. Am I thinking right?
I've seen pics of the CA-810 in the internet, rear panel, so I gues it can't be that hard. The plan is to add a Rotel "endstufe" to the Yamaha. :
http://www.uni-hifi.de/cms/upload/bi..._06/RB06_1.jpg
So the question is: Can anyone give me some hints? (best way to learn)
Thnx in advance,
Chris
Old 29th May 2013, 05:35 PM   #2
Welcome is offline Welcome  France
Welcome's Avatar
Do you have the schematic? If not - look here: Yamaha CA-410 | Owners Manual, Service Manual, Schematics, Free Download | HiFi Engine
What you need to do is the following:
Lift the leg of C451 and C452 that is connected to R435 and R436. Then lift the legs that went from the resistors to the capacitors. The legs you just lifted from the capacitors are MAIN IN (for the left and the right channels, respectively) and the legs you just lifted from the resistors are PRE OUT (again, one for each channel).
And that's it.
(At least, that's how I would to it. Probably, someone will correct me after this... hehehe).
Old 29th May 2013, 08:12 PM   #3
I've put the schematics online now when following the link. Okay i'll study the schematics with the advise you gave. Its a beginning thnx
Old 30th May 2013, 12:33 AM   #4
This is my first time also with pre-amp and main amp. So if I understand it right the only thin I should have to do is to "lift the resistors" & cut of the main amp. This signal is called "pre-out", is around 2 Volts. So if I would really do it nice i'll just make a switch inside. So when one wants to use the integrated Yamaha amp this will also be possible.
I'm I correct?
I've already seen some crazy Yamaha main amps for about 100 euros. With tone control. It would be really nice if it is this easy to connect one. Is it?
Old 30th May 2013, 08:20 AM   #5
Welcome's Avatar
Yes, that's all you need to do. The switch thing will work, too.
And of course, doing this will let you use any power amp with the system.
I normally take both pre out and main in, and wire them to four RCA plugs in the back (usually the tape in / tape out -loop, because I don't need that) and connect a short cable between them (or if I have them, those metal links that amps usually come with), for full integrated amp functionality.
Old 30th May 2013, 11:00 AM   #6
You can do this with a single 4pole or 5pole plug & socket. Like a DIN or XLR socket.
Wire all 4 lines to the socket poles. Inserting a "shorted" plug gives you a straight through. Or you can use the socket as a line out and Straight through, or as line out only or as line in only.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 30th May 2013, 01:42 PM   #7
This is really nice. Then I only have to replace the signal/tone caps. But they are mounted upside down for 35 years and the seem to be nice. So that can wait. And I only have to do the thing for the (example) the tape signal path. The tone control are mostly "tantaal" caps. Guess the will be fine to. Just a bunch of solid material. Or I'll visit someone with a oscilloscoop to really see wat have to been done.
Im gonna make it a hell of a beauty. I have seen that Velleman has a simple MP3 dac.
Wait for it. This makes electronics really fun!
Old 31st May 2013, 07:27 AM   #8
Welcome's Avatar
Tantalum caps in vintage electronics seem to be rather controversial topic. Some claim that they must be replaced as soon as possible, due to them having a dangerous failure mode where they short out (taking out other things in the process), and can even catch fire.
It's probably not going to happen, but it's worth considering.
Old 6th July 2013, 08:22 PM   #9
Many thanks guys! Ive uploaded the final pictures. I replaced the cap nr's 443 &444 with Elna's from a donor 930QS Sony. The sound is realy incredible. I had the Yamaha since the DA50ES. Also the Elacs. And I can say that this amp realy kicks ***. Every week there go's 5 bucks into the amp. (ssssst) As long as it plays, or until I have enough for a AS-3000. But I will listen to it first. Im not impressed by MOSFET advertising anymore aldo a fet amp sound really clear. The 930QS well thats another story. Wait for it.
Adding pre-out / Main-in to Yamaha Receiver (RX-V467) batam Construction Tips 4 29th December 2012 08:08 PM
Nakamichi 410 Pre + 420 Amp east electronics Solid State 7 20th September 2012 10:24 PM
Trying to add pre out/main in to integrated amplifier. Am I thinking right? Coconuts 500 Solid State 11 20th August 2011 11:34 PM
YAMAHA CA 700 east electronics Solid State 1 10th January 2011 08:44 PM
Copyright 1999-2017 diyAudio
