Retro Amp 50W Single Supply
Old 11th July 2017, 08:46 AM   #251
ff12 is offline ff12
Originally Posted by ff12 View Post
Hi guys
I've just built the amp and works just fine with low volume but when I turn up the volume low frequencies start to crash but high frequencies are just fine
can anyone help me ?
Old 11th August 2017, 09:25 AM   #252
Bruce@bluff is offline Bruce@bluff  South Africa
Has anyone tried running this amp in bridge sort of like a crown floating grounded bridge?
If it distorts on low frequency it could be due to insufficient current or type of oscillation called motorboating put a 100Hz signal in and check with a scope
Old 13th September 2017, 03:26 PM   #253
Legion is offline Legion  Poland
I know It's a dumb question but can I modify this amp in order to run it from dual +-40v power supply ?
Old 13th September 2017, 05:31 PM   #254
Mooly's Avatar
It could be done. The main problem would be DC stability of the amplifier output and so a servo (OpAmp) would normally be used. There are a few other small things to change as well.
Why do you want to try doing this ?
Old 13th September 2017, 11:42 PM   #255
wg_ski is offline wg_ski  United States
Just use the 80 volts as a single rail and ignore the center tap? Of course keep the output coupling cap....
Old 14th September 2017, 03:30 AM   #256
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
The beauty of this amp is its single rail. There are countless other dual rail amps to choose from in this Forum or even in Apex Audio's collection of amps. Why try to make an orange out of an apple? If you like oranges, eat an orange.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 28th September 2017, 12:14 PM   #257
I'll leave it with the single supply and try with +80v
Another question : Maybe instead of 1N4148 I'd use 2x double Schottky To220 and mount it on top of the TO3 transistor ? I'd improve much the temperature compensation I guess.
Old 28th April 2018, 09:37 PM   #258
prasi is offline prasi  India
prasi's Avatar
Mr. Mile,
Just came across this thread, apologies, if the question is already answered. Can the o/p be modern devices like MJL4281 and drivers MJE150XX
regards
Prasi
My revamped site https://sites.google.com/site/analogdesign1234/
Old 28th April 2018, 10:16 PM   #259
indianajo is offline indianajo  United States
indianajo's Avatar
Sure, why not? I had TO3 heat sinks in my single supply chassis, blown up, so I used NTE60 (white box MJ15003). If I were building from scratch I'd use MJL4281 or MJL21194, since the single hole is easier to drill and tap with a hand drill motor. Hard to get four holes to line up right with a hand drill motor.
MJE15028/29 or MJE15032/33 should work better for drivers than the TIP41C/42C I used. Just they were $4.50 each a couple of years ago, now down to $1.25 from Newark.
You can't use the PCB layout on page 1 if you are going to use TO3-P transistors. It is for TO3.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 29th April 2018, 04:23 AM   #260
prasi's Avatar
Thank you indianajo!
Retro Amp 50W Single SupplyHide this!Advertise here!
floating supply amp with single supply hitsware Solid State 2 2nd September 2011 09:41 AM
10 W Class AB amp: Adapting Single Supply to Dual Supply jonatmudd Solid State 13 18th March 2011 07:02 PM
Single Supply Amp help - LM3886? GePeW Chip Amps 104 22nd November 2007 10:38 PM
The Most Powerful Single Supply Amp?? segasonicfan Chip Amps 13 6th October 2005 05:38 PM
