#11 |
A very interesting article. Nice one Alex, I will build this one and see what I can learn from a design point of view.
#12 |
Brownlow,
Mail me privately with your address and I'll send you a photocopy of the JLH article. Alex |
#13 |
*28* transistors!?!
Whew! Clearly, the JLH phono stage isn't designed in the simpler-is-better mode... I just had a second and took a quick look at the Hart electronics site. You'd think for throwing that much silicon into the thing that they could do better than a 26 dB S/N ratio. Grey |
#14 |
Looking at the Williams Hart website, I noticed that the
specification is "26dB below surface noise", rather than "26dB S/N". I haven't seen this spec before. Does anyone know what this means? Is there an ANSI standard surface noise?. I assyme that the real S/N is much better than 26dB. Alex |
#15 |
I don't know about the version supplied in the kit, but
the original JLH circuit has 14 transistors per channel, which seems fairly normal. The stereo board has 28 in total. Alex |
#16 |
Alex,
I understood that it was 14 per channel. (Hoping, anyway. Egad, the idea of 28 per channel is horrifying.) I, for one, don't regard the idea of 14 transistors per channel as encouraging. I do make an exception for circuits that run multiple gain devices in parallel to lower noise and/or output impedance, but somehow I don't think that's the case, here. It's been a long time since I've seen anyone use the "below surface noise" phrasing. Note the vagueness--surface noise of a new record? of a ragged out party record? of a special test album? It says nothing. It's safest to assume that this thing is noisy, and that they're being vague in order to avoid being pinned down. In the past (and I mean a long time ago) people used to use semantic tricks like this to sidestep measurements that could be meaningfully compared to their competitors' numbers. (Yet another reason not to join the "Specifications Are Everything" crowd--you can't trust many of the published numbers...) Assume that -26 dB is a *best* case scenario and go from there. Caveat emptor. Grey |
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 05:46 PM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 09:51 PM |
| Designing a phono pre. #1: high gain block | Onvinyl | Analog Line Level | 11 | 6th November 2007 07:16 AM |
| Help designing Input and Vas stage's | DoomPixie | Solid State | 28 | 13th January 2006 09:28 PM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 06:41 AM |
