1000W Simple PA Amplifier
Old 8th July 2014, 12:07 PM   #611
ekoinsky is offline ekoinsky  United States
protector using IC555 with a few changes.
discard the clip limiter and plus speed fan control. works very well for almost 6 months.
regards
Old 9th July 2014, 06:06 AM   #612
wattaniya is offline wattaniya
regards
thanks for the reply,
which amp u used for this protect .?
can u share the layout of ur protect?
Old 10th July 2014, 04:57 PM   #613
wattaniya,
I use a protector for BX500TEF.
I'm just an amateur designer, only used for hobby only. but it all worked out very well.
regards respect for mr. mile for all his contributions, I really appreciate it.
thks.
Old 10th July 2014, 08:04 PM   #614
SYAHRUL is offline SYAHRUL  Indonesia
SYAHRUL's Avatar
bx500
Old 10th July 2014, 10:01 PM   #615
Driex is offline Driex  Bahrain
Banned
wattaniya,
thks.
Sir can you share the blue component guide in high resolution, sorry but its unreadable.
Thanks and regards,
Old 11th July 2014, 09:56 AM   #616
R.I.P.
did you look at the pdfs included in his/her post?
regards Andrew T.
Old 11th July 2014, 10:58 AM   #617
Boedy is offline Boedy  Indonesia
Boedy's Avatar
wattaniya,
thks.
thanks for share &
what u use component in pcb protect :
1. RELAY type : ?? A =
vdc =
2. Transistor serial..????
3. Sensor fan...???
4. Sensor Protect ..
Old 11th July 2014, 03:41 PM   #618
Thanks and regards,
i can't post with high quality. limited size picture. maybe this picture can help you. regards
Originally Posted by Boedy View Post
thanks for share &
vdc =
3. Sensor fan...???
1. relay 12VDC, rating ampere lupa bos.
2. u can use anything small transistor for Q1,but remember of NPN. for Q2=tip32 / anything PNP.
3. sensor fan, no use. automaticaly detect from out amp.
4. NTC 10K to heatsink, heat protect. but this protect work fine without it.
schematic of sensor fan attached.
thx. regards
Old 11th July 2014, 06:16 PM   #619
Boedy's Avatar
@Mas Ekoinsky thanks for reply..
I like ''Lupa boss'' :bd :bd :bd
Old 11th July 2014, 11:19 PM   #620
Banned
thx. regards
Thank you sir...
1000W Simple PA AmplifierHide this!Advertise here!
1000W PA Quasi NMOS Amp - Class H Stepdriver possibile ? NMOS Solid State 29 5th May 2017 03:42 AM
1000W tube amplifier Helmuth Tubes / Valves 50 5th July 2016 08:06 PM
1000W Class D Amplifier Module KatieandDad Swap Meet 2 27th October 2013 03:53 AM
1000W amplifier -- This is great schematic DigiSoft Solid State 45 27th September 2012 12:34 PM
My new 1000W PA amp (pic post) matth Solid State 78 27th October 2003 09:23 AM
