1000W Simple PA Amplifier
Old 13th May 2013, 10:41 AM   #11
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by nigelwright7557 View Post
If you use an IRS2092 class d based design with gate drivers you can get 1000watts out of 4 output transistors.
Agree, but some people don't like class D amps.
Old 13th May 2013, 10:45 AM   #12
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Mr. Mile can you post PCB please...
Thanks.....
Old 13th May 2013, 10:47 AM   #13
apexaudio's Avatar
Thanks.....
PCB not finish jet,
Old 13th May 2013, 10:53 AM   #14
wiljj78's Avatar
Default Ok, waiting for that....
I believe many diy friends will build this amp, including me...
Old 13th May 2013, 11:04 AM   #15
R.I.P.
Originally Posted by JMFahey View Post
.......... but it will be a nightmare to dissipate all those watts wasted as heat...........
With 1r0 emitter resistors on the outputs, the output bias will be approximately 26mA for optimum ClassAB.
This gives an output stage dissipation of ~51W for all 18 devices. Add another 6W for the drivers. Quite manageable, especially for a "big" amplifier that will probably be fan cooled.
regards Andrew T.
Old 13th May 2013, 11:47 AM   #16
apexaudio's Avatar
This amp will be cooled with two 0,14A/220V fans in parallel 120x120mm size.
Old 13th May 2013, 11:52 AM   #17
R.I.P.
What about SOAR of a 9pair 1943/5200 stage when operating from a 110Vdc supply?
regards Andrew T.
Old 13th May 2013, 12:45 PM   #18
apexaudio's Avatar
Will be ok for audio purpose.
Old 13th May 2013, 12:59 PM   #19
apexaudio's Avatar
Many diyers love old school amps with classic design without cascodes or class H operation, just simple current mirror VAS and EF output stage
Old 13th May 2013, 01:09 PM   #20
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Hi Apexaudio
greetings is it possible for you to post limiter and protection schematic
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
1000W Simple PA AmplifierHide this!Advertise here!
1000W PA Quasi NMOS Amp - Class H Stepdriver possibile ? NMOS Solid State 29 5th May 2017 03:42 AM
1000W tube amplifier Helmuth Tubes / Valves 50 5th July 2016 08:06 PM
1000W Class D Amplifier Module KatieandDad Swap Meet 2 27th October 2013 03:53 AM
1000W amplifier -- This is great schematic DigiSoft Solid State 45 27th September 2012 12:34 PM
My new 1000W PA amp (pic post) matth Solid State 78 27th October 2003 09:23 AM
