No NFB line amp (GainWire mk2) - Page 2 - diyAudio
Old 10th May 2013, 04:37 PM   #11
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by manso View Post
Damir, you should try to use a zobel filter at the output buffer instead of the output resistor. There are several disadvantages with that resistor. Another way is compensation by using a RC network from the output to the input of the buffer. This will probably give the best results.
Thanks manso,
Could you explain what disadvantages with output resistor? Similar resistor is normaly used to prevent an OPA to oscilate with capacitive load.
I tried different ways to compensate and used compensation worked well in the simulation.
I will try your zobel and RC suggestion.
Damir
Old 10th May 2013, 04:53 PM   #12
Loss of bandwith, slewrate and output impedance is increased.
I dont know why Opamp manufacturers dont suggest the use of zobel networks, these have the disadvantage that the zobel should be tuned to cancel the effect of the capacitive load, the problem being the use of different loads requiring different zobel characteristics for optimal stability.
Old 10th May 2013, 04:58 PM   #13
dadod's Avatar
Damir, you should try to use a zobel filter at the output buffer instead of the output resistor. ......... Another way is compensation by using a RC network from the output to the input of the buffer. This will probably give the best results.
Here is gain simulation with your suggestion and indeed it works, but with a bit higher distortion at 20kHz. Could be that my values are not the best.
Thanks Damir
File Type: jpg GainWire-mk2-e-elvee-dado-buffer-2-gain.jpg (235.3 KB, 1097 views)
Old 10th May 2013, 05:24 PM   #14
matze is offline matze  Germany
Originally Posted by dadod View Post
C2 and R19 are here to stabilize the amp, as it should work with long cable, means capacitans. I simulate up to 1nF.
One would expect that R19 already does sufficiently isolate the first stage from buffer and capacitive load. Nevertheless, you include C2 and additionally change it from 47p to 10p in the version with cascoded buffer. Why is C2 necessary?
Matthias
Old 10th May 2013, 05:32 PM   #15
Thanks Damir
I would not disconnect compensation of the cascodes.
What are these resonances at about 20MHz and 100MHz? Do they already appear without the buffer?
Matthias
Old 10th May 2013, 08:20 PM   #16
Originally Posted by matze View Post
Hi Damir,
the usual performance from you ....
Kind regards,
Matthias
The Shoe Is The Sign - The Beginning - YouTube
Old 10th May 2013, 08:40 PM   #17
dadod's Avatar
Originally Posted by stinius View Post
Old 10th May 2013, 08:48 PM   #18
dadod's Avatar
Matthias
Hi Matthias,
Here is the gain plot without output buffer. First one is without C2 and second with C2.
BR damir
File Type: jpg GainWire-mk2-e-elvee-dado-gain-noC2.jpg (239.5 KB, 1006 views)
Old 11th May 2013, 09:36 AM   #19
Holy grail! And Cheers!
Old 11th May 2013, 09:42 AM   #20
Thanks Damir
Interesting, some performance is lost. Can it be made stable if you remove the zobel and only the RC in place ??
Line stage with u-follower and nfb Groucho2004 Tubes / Valves 6 26th April 2012 10:00 PM
Cambridge A1 (mk2) Line-Amp Stage Power Suppy vcmarshall Solid State 0 25th April 2010 06:16 PM
Another no overall NFB amp npnp Solid State 9 8th April 2010 09:12 PM
Improved PSU for Technics SL1210 MK2 and SP 10 MK2 (and others) beetle Analogue Source 21 19th January 2010 11:25 PM
GainWire Mad_K Chip Amps 7 29th December 2003 05:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
