No NFB line amp (GainWire mk2) - Page 13 - diyAudio
Old 6th August 2013, 09:03 PM   #121
smms73 is offline smms73  Portugal
smms73's Avatar
I use the bob cordell method.
Ps: I can try to solve the problem... if you want, of course.
Sérgio Santos
Old 6th August 2013, 09:10 PM   #122
dadod is offline dadod  Croatia
dadod's Avatar
You can't use Bob method here, it's not ordinary GNFB, use Thian probe or simple voltage probe as I used(good enough in this case). If you change resistors value or use inductor it will disrupt ODNF behavior.
Old 6th August 2013, 09:45 PM   #123
smms73's Avatar
the Thian Probe is a very good method.
I will have a closer look.
But at first look it seems similar to a classic GNFB , with the difference that the discrete circuit is doing the voltage swing , which facilitates the work of the opamp (less distortion), that only has to output the error voltage .
It seems a good technique for nested feedback loops.
But as I said , have to take a better look.
Sérgio Santos
Old 6th August 2013, 09:56 PM   #124
smms73's Avatar
You are right , the cordell method does not work here.
Sérgio Santos
Old 7th August 2013, 12:30 AM   #125
smms73's Avatar
This feedback method can have very low distortion, and I think that it can be use in a class B power amplifier with good results.
Is this protected by a patent? who invented?
but this circuit have some points that needs to be improved.
the settling time of the circuit is very bad .
Sérgio Santos
Old 7th August 2013, 03:19 AM   #126
cbdb is offline cbdb  Canada
Originally Posted by dadod View Post
Why it would be -12V, it will be just enough to set output DC close to zero.
Why? There is no feedback from output to that point.
Old 7th August 2013, 05:30 AM   #127
dadod's Avatar
Thanks for the simulation, probably it needs input lowpass filter.
Sorry, highpass filter!
Old 7th August 2013, 05:31 AM   #128
dadod's Avatar
Yes there it is, ODNF op amp. Try to simulate.
Old 7th August 2013, 09:54 AM   #129
smms73's Avatar
In post #125 the simulation was made with a lt1007.
here is with the original lme49710. First picture with the ODNF, second with the normal feedback.
the resistor P1 (10k) is slowing the feedback action.
third picture is without global negative feedback.
Sérgio Santos
Old 7th August 2013, 10:17 AM   #130
dadod's Avatar
What are you talking abouth here, what normal feedback??
In second case this is not any more my pre amp, you disconnected the gain block completely and op amp acts as the gain stage, please don't do that!!!
I am not sure you understood the main concept here.
Line stage with u-follower and nfb Groucho2004 Tubes / Valves 6 26th April 2012 10:00 PM
Cambridge A1 (mk2) Line-Amp Stage Power Suppy vcmarshall Solid State 0 25th April 2010 06:16 PM
Another no overall NFB amp npnp Solid State 9 8th April 2010 09:12 PM
Improved PSU for Technics SL1210 MK2 and SP 10 MK2 (and others) beetle Analogue Source 21 19th January 2010 11:25 PM
GainWire Mad_K Chip Amps 7 29th December 2003 05:48 AM
Copyright ©1999-2017 diyAudio
