No NFB line amp (GainWire mk2)
Old 10th October 2013, 05:20 AM   #211
padamiecki is offline padamiecki  Poland
Originally Posted by Joachim Gerhard View Post
I can send you a decent MC Cartridge.
You need it.
Hi Joachim
You can send one for me, I need it too
regards, Pawel
Old 10th October 2013, 05:15 PM   #212
dadod is offline dadod  Croatia
dadod's Avatar
Here is corrected layout with thermaly connect Q13/Q15 and Q14/Q16. I hope I did not make mistakes, but is someone has a time to check.
BR Damir
Old 10th October 2013, 06:39 PM   #213
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Ola Sergio
Another special riaa... that is my cup of tea..... please post the schematic..... Does it use any servo to control DC offset ?
RC
Old 12th October 2013, 04:12 AM   #214
cast is offline cast  China
Default Current Audio Signal Transmission
Old 14th October 2013, 10:11 AM   #215
dadod's Avatar
BR Damir
Prototype board ready. I have bought 100 peaces of ONSEMI BC550C/560C and now I have to match them and I hope I've got enough of them.
BR Damir
Old 19th December 2013, 11:55 AM   #216
dadod's Avatar
This is proto board used for testing.
Old 19th December 2013, 12:04 PM   #217
dadod's Avatar
I gave up of using ODNF in this pre amp. Now it is going to have two possibility, NGFB, and CFA, and it is set by one jumper, J2 on is NGFB and J1 on is CFA operation.
ODNF is not easy to adjust, and CFA gives the same very low distortion. Now I can choose between those two operation and could compare the sound quality.
As the switch between NGFB and CFA shows different DC offset, DC servo was added.
Simulated THD:
NGFB output 4.5 Vpp
-------------line out phone 300 ohm phone 32 ohm
THD20k 10 ppm 14 ppm 0.01%
THD1k 8 ppm 12 ppm 0.01%
CFA output 4.5 Vpp
THD20k 0.05 ppm 0.15 ppm 2.55 ppm
THD1k 0.00 ppm 0.03 ppm 0.71 ppm
Output simulated level is more then enough and in more cases lower level is going to be used and with much lower distortion(NGFB).
I decided to make one PCB for dual mono with shunt regulator included. It needs a transformer and input selector + volume control to get complete line and phone preamplifier.
BR Damir
Old 20th December 2013, 12:35 PM   #218
Krisfr is offline Krisfr  United States
Krisfr's Avatar
BR Damir
I got 300 each, but they are from mouser - Fairchild....
Never give a Systems Analyst a screwdriver or hammer
Old 20th December 2013, 12:38 PM   #219
mcd99 is offline mcd99  United Kingdom
Quick question.
Do you rate Fairchild devices above the OnSemi equivalent? I've always thought the opposite.
Old 20th December 2013, 12:48 PM   #220
Krisfr's Avatar
Originally Posted by mcd99uk View Post
Quick question.
Oh no, I just got some BC550 and 560 from mouser, I did not know that there was a big difference between Fairchild and On Semi... maybe I need to get some from On Semi instead... Mine read BC550CBU... Is that GOOD or BAD?
The On Semi are 10 cents and the Fairchild are 6 cents... in hundreds... so maybe I can get some more
No NFB line amp (GainWire mk2)Hide this!Advertise here!
Line stage with u-follower and nfb Groucho2004 Tubes / Valves 6 26th April 2012 10:00 PM
Cambridge A1 (mk2) Line-Amp Stage Power Suppy vcmarshall Solid State 0 25th April 2010 06:16 PM
Another no overall NFB amp npnp Solid State 9 8th April 2010 09:12 PM
Improved PSU for Technics SL1210 MK2 and SP 10 MK2 (and others) beetle Analogue Source 21 19th January 2010 11:25 PM
GainWire Mad_K Chip Amps 7 29th December 2003 05:48 AM
Copyright ©1999-2017 diyAudio
