Impedance matching in hybrid amp - diyAudio
Old 7th May 2013, 04:24 PM   #1
Default Impedance matching in hybrid amp
Hello, everyone
I'm trying to design a hybrid amplifier with 6N2P (12AX7) input stage and emitter follower output stage (see schematic, please - maybe I explained it improperly).
So question is - how to match the impedances of these stages? Do I need some matching stages, for instance, cathode follower? (I've seen something like this)
I took this output stage design from audio amplifier circuit, designed by Russian engineer A.Ageev in 1982 - it is very simple and unusual design - its thermostability is achieved by installing all the transistors close to each other, on same heatsink.
And, as I read on audio forums, this amplifier sounds really good.
So, input stage is "classical" common-cathode amplifier with automatic bias.
Also I plan not to place a negative feedback around the amplifier.
I haven't calculated the values of passive components yet, because I'm not sure that this design will work.
I attached the circuit of Ageev's amp and my draft.
Thanks in advance! Michael.
Old 7th May 2013, 05:40 PM   #2
ilimzn is offline ilimzn  Croatia
You have not copied the schematic of the output stage correctly (exchanged emitter, collector)
Old 8th May 2013, 04:53 PM   #3
I'm sorry!!!
Here is correct variant.
Tube amp OPT for Headphone Amp? (impedance matching question) rongon Tubes / Valves 21 3rd January 2012 05:20 AM
Speaker impedance and amp matching? Skorpio Tubes / Valves 2 10th September 2011 07:22 AM
Help with matching speaker impedance to old tube amp idebb Tubes / Valves 8 11th April 2010 05:18 AM
impedance matching to a pro amp... MyNameIsJake Solid State 2 4th June 2006 06:32 PM
Impedance Matching & Crossover network query Redhatter Multi-Way 0 6th January 2004 08:59 AM
Copyright ©1999-2017 diyAudio
