New type Zobel = <THD - diyAudio
Old 6th May 2013, 10:20 PM   #1
Zero D is offline Zero D  United Kingdom
Lightbulb New type Zobel = <THD
Well new to me anyway
Been tinkering again
I've only shown the relevant parts, but the full simmed Amp shows lower THD with this configuration. Not much lower i admit, but lower = Lower
@ any level below clip it went from 0.004% - 0.003% @ 1kHz. @ 10kHz it went from 0.034% - 0.020%
I havn't extensively tested this, or changed the caps/res much, as i've just done it. The values of the Zobel components as shown are just examples of what was achieved so far. Other values/components may be substituted.
Further options "could" be as in screenie 2 & 3 for eg, and/or variations on the same theme.
If it's not new, why don't vendors etc do it ?
Old 7th May 2013, 12:23 AM   #2
djk is offline djk
djk's Avatar
Mark Levinson ML3.
Candidates for the Darwin Award should not read this author.
Old 7th May 2013, 08:08 AM   #3
Why did you choose emitter resistor at 4r7 for a power amp?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 7th May 2013, 08:25 AM   #4
Real loudspeakers are not 8R2 resistors. Up to a few nF of cable capacitance is the problem
Old 7th May 2013, 03:22 PM   #5
@ djk
Thanks, i'll try & find the circuit diagram ! Interesting that it does actually work Even if i wasn't the firstt o discover it.
@ AndrewT
It was a headphone amp sim i had on hand.
@ davidsrsb
Indeed
Old 7th May 2013, 03:53 PM   #6
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Fine, but then it might be useful to re-simulate with real Power Amp values.
Using, say, 0.47 to 0.1 ohms (which would be the actual value range) makes me think that the already minuscule distortion reduction will be even smaller.
Old 7th May 2013, 06:27 PM   #7
@ JMFahey
I tried it with 0.25 Ohms & you're right it @ 1kHz anyway it was still 0.003% !
My motto is, if you don't experiment, you might never know what's Actually possible. Sometimes good things have been discovered just by tinkering
Old 7th May 2013, 09:49 PM   #8
JMFahey's Avatar
Fully agree
But I had a gut feling that a smaller ballast resistor would put both feedback points closer to each other.
Thanks for checking.
LT AN67 Ultralow THD 10kHz sine oscillator group buy. Frex Group Buys 63 6th March 2016 07:36 AM
Silicon Chip Ultra-LD Mk 3 < 0.004% THD @ 20KHz Trevor White Solid State 1 2nd July 2011 01:26 PM
12v chipamp w/ ~100watt THD+ N <0.05% FastEddy Solid State 4 16th July 2007 01:39 AM
DIY-AMP &lt;ZAS&gt; Low THD &amp; IM high bandwith murphy Solid State 18 30th December 2005 10:28 AM
Copyright 1999-2017 diyAudio
