Bob Cordell's Complementary IPS-VAS topology - diyAudio
Old 5th May 2013, 04:48 PM   #1
danny92 is offline danny92  Portugal
Default Bob Cordell's Complementary IPS-VAS topology
Hi everyone,
I'm simulating this circuit that is based in one circuit found in Bob Cordell's book, this circuit has good characteristics, but this is really stable in the real world, does anyone tested something like this ?
I'm thinking about using a thermal shutdown network connected to the mute network, using Schimitt Trigger configuration, and I should also use a S/C protection circuit, but I don't know if I should use a single slope VI limiter, or a multislope VI limiter.
Thank you very much for your support
Best regards,
Daniel Almeida
File Type: png Complementary_IPS_bjt_MOSFET_output.png (39.1 KB, 590 views)
File Type: asc MOSFET2_Comp_IPS_VAS_Current_Mirror.asc (15.5 KB, 48 views)
Old 5th May 2013, 05:01 PM   #2
Banned
I am doubtful that this circuit would work in practice. And yes, use a VI limiter; send me your email address and i'll send you an article on VI limiters. What sort of Schmitt trigger do you intend to use?
You could use the VI limiter connected to opto-coupled transistors to trigger a bistable latch that remains triggered ounce VI limiting is invoked until power is cycled.
Old 5th May 2013, 05:08 PM   #3
This circuit won't work? why?
My email adress is: danielgpsalmeida@hotmail.com
Best regards,
Daniel Almeida
Old 5th May 2013, 05:20 PM   #4
Banned
Because I am not certain that second stage standing current would be well controlled in reality. But I think you should consult the circuits author on this point.
Check your mail.
Old 5th May 2013, 05:25 PM   #5
Can suffer from quiescent bias current instability in the VAS, right?
Bob Cordell said that the 47kohm shunt resistor in the differential pairs should solve the problem, but I'm no sure about that, I've written in Bob Cordell's book thread.
Thank you for your help,
Best regards,
Daniel Almeida
Old 5th May 2013, 05:28 PM   #6
Banned
Bob Cordell said that the 47kohm shunt resistor in the differential pairs should solve the problem, but I'm no sure about that....
Yes, you need to establish from Bob Cordell whether he's actually built the circuit to verify this.
Old 5th May 2013, 05:36 PM   #7
Can you send me your VI limiter articles, please?
I'm thinking about using the mute network connected to a Schmitt trigger comparator, and then comparing a resistive voltage divider's voltage, with NTC voltage divider's voltage, the window will shutdown the amplifier at nearlly, I don't know, some temperature between 70 and 100 șC and the device will only be reactivated at a lower temperature between 60 and 90 șC, I don't know if that is possible, if so, what model of comparator I should use?
Best regards,
Daniel Almeida
Old 5th May 2013, 05:48 PM   #8
Thank you very much for the articles
Best regards,
Daniel Almeida
Old 9th May 2013, 09:47 PM   #9
Struth is offline Struth  Canada
Banned
Hi Guys
Yes, the idle current in the VAS is predictable and stable with the above circuit. The third Q in each mirror, Bob calls a "helper transistor'. This Q establishes the voltage on one side of the mirror. If the mirror balances, then the voltage at the output side is identical, with zero current through the 47k.
In the end, the diff tail current sets the voltage drop across the emitter Rs in the mirror. The voltage across these Rs is identical to that across the VAS emitter R, so VAS current is set by resistor ratios and the diff-amp tail current.
The same applies to the front-end of Bob's mosfet amp from 1983.
Have fun
Kevin O'Connor
Old 9th May 2013, 10:36 PM   #10
Ok, thank you for your help,
Best regards,
Daniel Almeida
Bob Cordell's Power amplifier book ihan Solid State 8072 18th January 2017 06:56 PM
Problem with Bob Cordell's LME49830 and LT1166 mantabernd Chip Amps 14 26th August 2016 01:49 PM
Another realization of Bob Cordell's THD Analyzer giulianodes Equipment & Tools 136 6th June 2016 09:06 AM
Bob Cordell's VinylTrak jan.didden Analog Line Level 61 26th March 2015 01:05 AM
PS with boosted rails for IPS, VAS and Pre-Drivers jkuetemann Power Supplies 2 29th March 2011 01:12 PM
Copyright ©1999-2017 diyAudio
