Adcom power light goes out fast when powered down? - diyAudio
Old 5th May 2013, 03:12 PM   #1
Default Adcom power light goes out fast when powered down?
I have an adcom gfa-5503 that I just bought and the power light should stay on for 30 seconds or so but it goes out in 3 seconds when powered down. I have a 555 that stays on for at least 30 sec. Does this mean the large power capacitors are bad? Also the transformer is rather loud.Loud as in buzz, and the loudness of the buzz is affected by other components being turned on or off. Any help here would be appreciated. Where to start ?thank you so much.mike
Old 5th May 2013, 06:26 PM   #2
djoffe is offline djoffe  United States
HiFi Engine didn't have schematics, so the following things are just SWAGS.
Amongst the causes of a buzzing transformer:
1. Extraordinary load - in which case, something would be getting warm.
2. Diode bridge with an open leg...draws upbalanced current, makes the transformer buzz pretty badly. You can see this with a scope on the filter caps, as the ripple freq would be 60 Hz, not 120 Hz.
If you can measure the voltage across the big caps before, at, and after turnoff, you'll have a lot better than these SWAGs to go-on.
Akitika GT-101 Audio Power Amplifier Kit
Update My Dynaco
Old 5th May 2013, 10:08 PM   #3
Ok the amp does run very warm the sinks run around 125 deg f. But from what I have read its normal. I will measure across the caps like you said and see what I get. Thanks
Old 6th May 2013, 12:20 AM   #4
If the amp pulls enough current, bias or otherwise, to run at 125F, then I doubt any realistic cap values will store enough energy to keep the power light on for 30 seconds. 3 seconds seems more realistic.
I may be barking up the wrong tree, but at least I'm barking!
Old 6th May 2013, 01:28 AM   #5
The amp has 6-18000uf caps and 12-1000uf caps in the power section. My friend has the same amp and his light does take a long time to go out to. But he said his amp doesn't run nearly as hot. So you could be right about the bias. I will measure the voltage as joffe said and I can also check the bridge rectifiers for open legs.I did find a few resistors that had a bad solder joint and they were actually rocking they were so loose. I am working 65+ hours a week right now so it's hard to find time to tinker with it. I should have next weekend to myself to get busy with it though. I might call a few electronic repair places near me and see if they could test the caps for me if they have a tester. That would rule that out. Thanks for all the help here. Over and out. Mike
Old 6th May 2013, 01:53 AM   #6
Here's a rough calculation.
assume +/-50 Volt rails, with 54000 uF on each rail. If the amp took 1 amp from each rail, the voltage on the caps would drop at the rate of 18.5 Volts/second
(assumes a constant current load).
That would be about 3 seconds for the light (3*18=54).
There's a darn good chance that either:
capacitance is lost, or more likely
bias current is much higher than it should be.
Update My Dynaco
Old 6th May 2013, 02:10 AM   #7
It's actually a 3 channel amp @200 watts rms. here is a pic it says 73 volts and 60 volts.
Old 11th May 2013, 06:49 PM   #8
Ok so I took the big caps out to be tested and the guy said they are good. He tested the esr and they all tested good. I also checked all 3 bridge rectifiers and they all tested good to my knowledge. With my dmm on diode check I got a reading 1 way and nothing the other way. So at this point I am going to clean everything up and put it togeather. I will power it up and check and set the bias and dc offset to spec and just see if that was the problem. The guy at the repair shop said that the bias might be too high just like a few of you did. I might pull the transformer off its mount and see if I could put some extra dampening between the mounts too. Thanks for all the help. Wish me luck. Mike
Old 11th May 2013, 07:22 PM   #9
5th element's Avatar
If the bias is set too high there's a strong chance that the transformer is buzzing because of the high(er) current draw. Setting the correct value may, therefore, help cure it. Adding in some felt, or similar, to the transformer mounting will be useful if the case is resonating with the transformer.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 14th May 2013, 01:32 AM   #10
I would like to go through the amp and replace a little more than just the 3 electrolytics on the amplifier pcb. I read a few post on here about some crappy sounding gfa5500 that is basically the same amp with mine having another channel. Mine is also lacking bass and the treble and mods are grainy compared to my 555. If I post a schematic, could someone pick some better components than what was used from the factory? I read about polystyrene caps being some of the best, can I use some of them? I would like to get the upper end to smooth out a little. Also there doesn't seem to be any detail compared to my gfa-555. I wouldn't mind spending a 100$ or so on capacitors and resistors if they get this amp sounding good for 10+ years or more. Ill work on getting the schematic up. The last thing I will upgrade is the big power caps. They supposedly tested good anyhow. Let me know what you think.
Fast light tvrgeek The Lounge 17 4th February 2013 11:37 AM
Troubleshooting a music powered LED light box. Wagge Everything Else 2 5th January 2012 11:56 PM
Fast diodes for power amps? carlmart Power Supplies 2 19th July 2011 03:44 AM
Fast Rectifiers for Power Supplies Bob Cordell Solid State 12 7th March 2010 01:04 PM
Copyright 1999-2017 diyAudio
