Problems with amplifier MX50 SE
Old 5th May 2013, 03:20 PM   #1
arielgam is offline arielgam
Default Problems with amplifier MX50 SE
Hi
I bought two plates of this amplifier (ebay chine)
I've ridden and I've fed AC35+35 (DC50+50)
I have been burned when ignition resistance.
Turn repidamente.
I have not tried the other channel because I have fear of burning.
As I can find the problem.
Thank you.
Old 5th May 2013, 07:19 PM   #2
djk is offline djk
djk's Avatar
Post the schematic link, and identify the reference number of the burnt resistor please.
Candidates for the Darwin Award should not read this author.
Old 5th May 2013, 08:57 PM   #3
burned resistance is 68 ohom
attachment scheme
Old 7th May 2013, 01:48 AM   #4
djk is offline djk
djk's Avatar
There are more than one 68Ω resistors, which one (use the reference designator on the schematic please).
Old 7th May 2013, 03:24 AM   #5
Ian Finch is offline Ian Finch  Australia
The resistor is probably R25 (closest to R23 and the PNP driver). The OP may be having a similar problem with the schematic as anyone else trying to follow it. It is bogus - I'd say intentionally, to foil copyists, as it specifies darlington drivers but the fitted transistors are apparently the Chinese versions of 2SD669/2SB649. Further, the part numbers are not reproduced on the overlay. There likely will be more errors to ensure failures if building from scratch using that version of the schematic.
Ian
Old 7th May 2013, 08:59 AM   #6
djk is offline djk
djk's Avatar
Are those 669/649 full-pack? Or are they missing their insulators, I can't tell.
He has the C12 100F cap in backwards, the resistor is probably R29. Cap shorted, resistor burned.
http://www.ebay.com/itm/LJM-MX50-SE-...-/230909190448
Old 7th May 2013, 09:31 AM   #7
djk is offline djk
djk's Avatar
LJM MX50 SE 100W 100W Power Amp Kit Stero Amplifier Kit DIY | eBay
Old 11th May 2013, 04:39 PM   #8
You're right.
It was a mistake of mine.
I solder a capacitor backwards.
Thank you all.
Old 20th May 2013, 05:56 AM   #9
augustoriodosul is offline augustoriodosul  Brazil
augustoriodosul's Avatar
Hi all,
I found it interesting parts welded far from the pcb, this should cause some loss in signal quality. I've assemble some of these MX50-SE but with SANKEN transistors - 2SA1186 Ft 60 MHZ and 2SC2837 Ft 70 MHz.The result is great mids and highs in a multi-amplified system. A simple amplifier, but it looks very good. Some pics in https://www.facebook.com/augustojose.hoffmann
Old 20th May 2013, 02:56 PM   #10
I've installed everything and have already exploited the two channels of amplification.
I've ridden with NE5532 preamp.
Have coupled the midpoints of the two transformers at the output of toroidal coils.
First you burn an amplifier and then the other amplifier.
Before turning to audio cocnector touch several times to prove that it worked, and then burned.
The preamp volume was the maximum.
The toroid is in AC-DC-35 +35 50 +50.
The smaller toroidal AC-12 +12
That problem could happen?
Problems before the amplifier output directly to the PC and sounded good. Warmed much heat sinks but not burned. (Only burn the filter upside down )
Problems with amplifier MX50 SEHide this!Advertise here!
LJM MX50 kit amp augustoriodosul Solid State 245 5th December 2017 06:42 AM
MX50 LAST VERSION - probably the best Stee Solid State 7 12th March 2014 08:15 AM
Still have voltage problems with Simple SE BillEpstein Tubelab 6 15th July 2011 02:54 AM
Simple SE grounding problems.. hartze11 Tubelab 7 24th May 2010 05:33 PM
Final checkout problems with Tubelab SE Mazuki Tubelab 11 21st June 2009 01:50 AM
