Old 4th May 2013, 05:43 AM   #1
Zero D is offline Zero D  United Kingdom
Lightbulb Compensate Amplifiers or Not ! & How best ?
Over the past few days i've been designing some new audio circuits. I decided to experiment with different values/types of compensation, instead of the usually quoted/shown ones. In this instance these are buffers.
For years in Numerous articles etc etc, for the feedback i've seen either, a direct link, a resistor, or resistor & capacitor.
I was surprised to see the differences between them ! I discovered that a solitory resistor was best
I realise the peaks are @ Very high f's, & it's a buffer, but i'm wondering if this discovery "might" affect the performance of other circuits in some way/s, positive, or negative, when other factors are taken into consideration, such as other means of compensation etc are included ?
Old 4th May 2013, 08:44 AM   #2
AndrewT is online now AndrewT  Scotland
The resistor in the unity gain feedback path is specified for some opamps.
There are a couple of opamp papers that suggest this resistor should always be fitted even when the datasheet does not mention it.
Old 4th May 2013, 02:11 PM   #3
DUG is offline DUG  Canada
I would not worry about anomalous behavior at 3.5MHz.
What amp model was used?
Doug We are all learning...we can all help
Old 5th May 2013, 11:45 AM   #4
@ AndrewT
Yes i've seen those.
@ DUG
I know but i found it interesting that it happens, & a good way to cure it.
It's an OP27
How do you compensate for a fold in a TL? kifeinthesink Multi-Way 3 18th November 2012 07:58 PM
Once you start compensate Konrad Subwoofers 3 9th December 2004 04:57 PM
how to compensate diffrence in amp gains in 3-amp system futiboho Solid State 7 15th October 2004 09:06 AM
to Miller compensate or not to Miller compensate capslock Solid State 117 26th June 2003 11:31 PM
Copyright ©1999-2013 diyAudio
