Active Crossover Activity thread
Old 9th January 2004, 01:03 AM   #91
BDP is offline BDP  United States
Yes,
The question for me is do I need gain to equalize the drivers or if the amplifier gains are not the same. Do I want the ability to change x-over points with out effecting each of the filters. If you build another amp this kind of versitility/ adjustability would be nice.
See what happens when you build too many amps??
Old 26th January 2004, 07:20 PM   #92
JensRasmussen is offline JensRasmussen  Denmark
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Default My idear for an active xover
Hi all,
I have made a plan for an active xover, but I need to make sure that I have included all I need for a flexible filter.
Please see the pic and comment on it.
It's a 4 way filter using 2 global EQ's and some EQ's in sub, bass, and midrange.
Thanks for any input.
Jens
Old 26th January 2004, 07:46 PM   #93
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: My idear for an active xover
Complete -- except maybe for time delay -- but very complex... you are going to have a little city of op-amps (or other active devices).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th January 2004, 10:55 PM   #94
Default Delayline
Well, I hope to make a digital version when I get my hands on a DSP eval board.
Here it would be easy to make the delayline.
The transformation to DSP is not to bad once all the analog math is done.
Is it ok to use dual opamps? or even quad?
\Jens
Old 26th January 2004, 11:41 PM   #95
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
You could also add a sub-sonic filter. Your amplifier will thank you.
Rodd Yamashita
Old 28th January 2004, 12:39 PM   #96
Default SMD or normal resistors
What would be best, SMD resistors or normal ones that need drilling?
SMD gives a smaller layout, but are difficult for most DIY folks to get. Normal resistors are alot bigger and more easy to come by.
Is there any difference in sound?
Are PP caps ok for sound?
What about OPamps, what do you prefer?
\Jens
Old 4th May 2004, 03:13 PM   #97
Boaz is offline Boaz
Default 3 way stereo Active Crossover summarize
Can anyone summarize things about building/buying active crossover of 3way-stereo (including performance and costs).
I want to upgrade my hi-end speakers (which I build and designed) with such a crossver and amps.
The crossover should have flexibility (freq, slopes, att) to support future use in other speakers design as I will want to use it for speaker designs (for my personal use).
Thanks!
Old 4th May 2004, 03:22 PM   #98
tiroth is offline tiroth  United States
Jens' active thread on analog crossover is here:
http://www.diyaudio.com/forums/showt...5&pagenumber=1
There is also moamps' project, which is a different take on the same basic idea:
http://www.diyaudio.com/forums/showt...threadid=27651
I must admit that I am currently organizing a group buy on a design that arose out of moamps' project. I think it is excellant in terms of tweaking/forward compatibility.
Old 4th May 2004, 08:48 PM   #99
Tiroth, Thanks.
I understand that your project is as same as the mox (just pcbs).
Do you have an estimation of the total costs?
If I'll use, as a a start, op-amps, the final sound will be much less?
Old 5th May 2004, 12:09 AM   #100
Boaz, why don't you shoot me an email or post in the group buy thread and we can discuss. I don't want to threadjack this one. Thanks.
Active Crossover Activity threadHide this!Advertise here!
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 02:29 AM
Copyright ©1999-2017 diyAudio
