2stageEF high performance class AB power amp / 200W8R / 400W4R
Old 6th December 2017, 02:35 PM   #2651
astx is offline astx  Austria
Yep! With +/-60VDC you get exactly 200W8R or 400W4R. That was the max. supply voltage of my test bench. With 600VA transformers the max. power below 1% THD20k was due to rail voltage sagging about 220W8R.
BR, Toni
Hint: have a look at first post of my threads for an updated index!
Old 6th December 2017, 06:32 PM   #2652
thimios is offline thimios  Greece
I have +/-100v d.c 1kW.
Old 6th December 2017, 06:58 PM   #2653
diyralf is offline diyralf
diyralf's Avatar
BR, Toni
I assume 60V is the DC voltage at loading caps while 200W/8ohm. What is your transformer AC voltage, how many uF's do you use?
Old 6th December 2017, 07:13 PM   #2654
No. The +/- 60V are from my 2 regulated PS maximum setting (per PS 2x30V in serial configuration).
If you use the described 650VA transformer and the big SA2014 PS pcb the rails are sagging to 62 - 65V if you play 220W continous. One monoblock PS uses 8 x 10000uf/100V lytics.
Old 6th December 2017, 09:47 PM   #2655
diyralf's Avatar
Thanks for the info.
Old 10th December 2017, 01:32 PM   #2656
diyralf's Avatar
Hello Toni. I always find good suggestions in your post. What did you pay for the TAUSCHER-transformer? I suppose that was 1 piece? Is there a hum to hear? Since it is shed, is there any smell? Presumably it will not have primary / secondary shielding.
Old 10th December 2017, 01:47 PM   #2657
I've ordered 6 pieces 600 VA custom made. Total cost incl. shipping was about 850 EUR. But you get them only B2B. Quality is very good. Mechanical hum only, if DC on AC line is present. No smell. Shielding can be ordered if wanted.
If you want B2C custom made transformery you can try toroidy.pl for example.
BR, Toni
Old 11th December 2017, 06:43 AM   #2658
diyralf's Avatar
Toroidy is 80% over priced.
Old 11th December 2017, 07:18 AM   #2659
I have other experience: my custom made transformers in a stainless steel pot housing from toroidy.pl look very professional at a reasonable price. Maybe another company is able to deliver the same custom made transformers at a lower price. But we can discuss this in an extra thread where you can summarize all B2C toroid manufacturers.
BR, Toni
Old 14th December 2017, 06:07 PM   #2660
diyralf's Avatar
The homepage says that the Toroidy transformers are shielded. Do they have a separate shielding cable?
2stageEF high performance class AB power amp / 200W8R / 400W4RHide this!Advertise here!
f5 based high power class ab amplifier 400kg Solid State 7 28th July 2014 02:21 PM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
High End AB Class Amp - Need recomendation velicko Solid State 19 12th November 2007 05:42 AM
Ultra-High performance OpAmp-based MOSFET Power Amp tlf9999 Solid State 20 7th September 2005 09:41 PM
