2stageEF high performance class AB power amp / 200W8R / 400W4R
Old 11th May 2013, 09:16 PM   #131
astx is offline astx  Austria
Originally Posted by astx View Post
New driver bjt's (2SC4793/2SA1837 and MJE15032/MJE15033) arrived ...
The good news: 2SC5171 and 2SA1930 can be directly replaced by 2SC4793/2SA1837.
The bad news: the distortion figure of THD20kHz@200W@8R was about 0.0034% before and is now with this drivers 0.005%.
Maybe a compensation tuning helps to get closer to the predicted 0.003% THD from simulation. Let's see.
A complete THD/power test is now running. So we can compare the THD results also for lower level signals.
BR, Toni
Old 11th May 2013, 09:45 PM   #132
Originally Posted by sajti View Post
The spice:
Sajti
asc file? Thank you.
BR, Toni
Old 11th May 2013, 11:16 PM   #133
BR, Toni
The completed THD power test shows significant higher THD levels from low to high power!
Perhaps the new drivers needs a rebiasing? The new drivers have better SOA so after some simulations i decided to change R17 from 150R to 68R.
Bingo! 10ppm better THD in real life!
THD20kHz@200W@8R is now at 0.004% (measurement floor of VP7723D is at 0.00106%)
THD1K@200W@8R is now at 0.00130% (measurement floor of VP7723D is at 0.00045%)
Old 11th May 2013, 11:36 PM   #134
keantoken is offline keantoken  United States
keantoken's Avatar
A 25% difference in THD is pretty small, think in logarithmic terms. I used to worry about small differences but eventually I realized thinking logarithmically allowed me to make gains of more than 6db. Unless your design is nearly finalized, you should not be satisfied with fractional gains or you will spend time on only the minor sources of distortion. Look for the major sources of distortion and focus on eliminating those. To do this requires developing methodology but really it's just a process of asking a question and devising a test that will answer it. Doing this you can figure anything out.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 12th May 2013, 12:15 AM   #135
you are right regarding THD levels! I see them as a sign that something can be done better. So I found the underbiasing problem of the new drivers very quickly. Also the distortion residual waveform is important and a good sign of stability or instability ...
Btw: It seems to be no more necessary to keep the 22p bridge above TPC in place. Amplifier is stable without it. Will optimize TPC the next days. Square root overshoot is stable - shows no ringing.
All 2SC5171/2SA1930 have now been replaced by 2SC4793/2SA1837 drivers. Slewrate increased from 45V/µs to about 80V/µs. Square root overshoot is TPC typically and stable - shows no ringing.
BR, Toni
Old 12th May 2013, 12:56 AM   #136
Default Distortion analysis for R17=68R / 22p removed
All 2SC5171/2SA1930 have been replaced by 2SC4793/2SA1837 including VAS drivers!
2SC4793/2SA1837 are biased with R17=68R
22p bridge capacitor (above TPC) removed.
Note: 20 and 200Hz measurements above 100W are inaccurate as lab powersupply current limiter has actived.
The second plot is the loop measurement of the analyzer itself for comparison.
Old 12th May 2013, 01:11 AM   #137
keantoken's Avatar
I've seen too many C5171/A1930 counterfeits than I'd like to have. It would not surprise me at all if yours were fakes and were causing stability issues.
At the same time, the C5171/A1930 are actually a bit faster than the C4793/A1830.
Hopefully removing the 22p TPC bridge lowers THD20. Eventually it may become evident that the only distortion left is that from the output stage base currents, in which case it will be time to improve the frontend or change OPS topology. Or let well enough be.
It is possible to correct the overshoot with an RC across the feedback resistor. The idea is to optimize TPC for 6db overshoot and then correct it by lowering gain above the TPC corner by 6db (other figures than 6db could work). This may seem superfluous, but it is important to limit overshoot so that you can test step response close to full output swing where 6db overshoot would clip badly. TPC is often oversized to prevent this overshoot but when it is allowed and corrected for, significant gains can be made (that is, if TPC was the dominant distortion mechanism).
Old 12th May 2013, 11:47 AM   #138
sajti is offline sajti  Hungary
BR, Toni
I will give it tomorrow, as it is in my home PC.
Sajti
Old 12th May 2013, 11:50 AM   #139
Try Mouser. They have stock, and I'm sure that they sell real Toshiba.
5171/1930 is faster, and have lower internal capacitances.
Sajti
Old 12th May 2013, 12:21 PM   #140
HarryDymond is offline HarryDymond  United Kingdom
Don't forget the C5171/A1930 are very fast (for their power rating) - as such they may be more susceptible to parasitic oscillations. astx may have been seeing this rather than global loop instability.
You say predicted THD with the new drivers is 0.003%, but what models are you using for the C4793/A1837?
2stageEF high performance class AB power amp / 200W8R / 400W4RHide this!Advertise here!
f5 based high power class ab amplifier 400kg Solid State 7 28th July 2014 03:21 PM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 09:52 PM
High End AB Class Amp - Need recomendation velicko Solid State 19 12th November 2007 06:42 AM
Ultra-High performance OpAmp-based MOSFET Power Amp tlf9999 Solid State 20 7th September 2005 10:41 PM
