2stageEF high performance class AB power amp / 200W8R / 400W4R - Page 12 - diyAudio
Old 10th May 2013, 09:57 AM   #111
keantoken's Avatar
Originally Posted by sajti View Post
I don't agree with You. I used triple EF in many amplifiers, without any problem. And the distortion is decreased to 1/10 of the original double EF version.
Especially the triple EF gives lower output impedance before feedback.
Sajti
It is all in the implementation. Most of the output stage distortion is voltage distortion, not drive distortion, so no matter how much you buffer it, miller and Early leakage will conduct its distortion directly into the signal path.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 10th May 2013, 11:52 AM   #112
sajti is offline sajti  Hungary
Originally Posted by kgrlee View Post
Sajti, have you a link to your circuits? Are these distortion figures 'real life' or SPICE?
Toni, thanks for the models.
Yes I have, so I will put it to this forum.
Both simulation, and measurement.
Sajti
Old 10th May 2013, 12:00 PM   #113
Yes, but the loop gain is increasing, and the higher feedback results lower distortion.
Sajti
Old 10th May 2013, 12:01 PM   #114
astx is offline astx  Austria
Default 2stageEF_MOSFET_class_AB_power_amplifier.asc
proudly present a pre alpha untuned MOSFET version.
But not yet ready for production test!
BR, Toni
File Type: asc 2stageEF_MOSFET_class_AB_power_amplifier.asc (37.3 KB, 251 views)
Old 10th May 2013, 12:44 PM   #115
Originally Posted by astx View Post
Dear Harry
thank you for answering. There is so many to learn how to measure amplifier stability correctly. The Tianprobe in the NFB loop is only one test. If you have some hints where to find the error in the minor loop which is only visible in real world design and not reproducable in simulation? Where to set which probe type in simulation would be helpful.
You should consult page 8 and the addendum in my paper and the references therein.
THX. Attached a new PSRR test. Hopefully now correct.
Don't forget that here you have only measured +ve rail PSRR. You will need to repeat the test but with the AC source in series with the negative-rail voltage source.
Old 10th May 2013, 12:56 PM   #116
keantoken's Avatar
Sajti
I never said an EF3 wouldn't decrease distortion if properly applied. I'm only pointing out that it takes skill to do this.
Old 10th May 2013, 01:06 PM   #117
Sorry, it was a misunderstanding.
Sajti
Old 10th May 2013, 01:17 PM   #118
Dear Harry,
thanks for hints. Attached a PSRR check also from negative rail - better as from positive rail.
BR, Toni
Old 10th May 2013, 01:30 PM   #119
Default New driver BJT's ...
New driver bjt's (2SC4793/2SA1837 and MJE15032/MJE15033) arrived today! Need matched bjt's.
Will this do with this homebrew "breadboard hellmachine". Can measure 10 pieces of BJT's/JFET's/MOSFET's automatically.
Needs up to 3 USB-controlled multimeters.
Old 10th May 2013, 02:45 PM   #120
5th element's Avatar
Lol very nice, I like it
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
f5 based high power class ab amplifier 400kg Solid State 7 28th July 2014 02:21 PM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
High End AB Class Amp - Need recomendation velicko Solid State 19 12th November 2007 05:42 AM
Ultra-High performance OpAmp-based MOSFET Power Amp tlf9999 Solid State 20 7th September 2005 09:41 PM
Copyright ©1999-2017 diyAudio
