Need help troubleshooting clone amp
Old 1st May 2013, 03:13 AM   #1
clm811 is offline clm811  United States
clm811's Avatar
Default Need help troubleshooting clone amp
Hi.
I bought some PCB's which are an adaptation of a Marantz MA9S2, but incorporate some custom changes(such as an op-amp-based DC servo), and utilizing multiple pairs ON-Semi 4218A/4302A with 62v rails.
See attached schematic
In testing I'm utilizing an incandescent light bulb in series with the variac, then the transformer, rectifier, caps, then F1A fuses in series with the VCC and VSS rails; milliamp meters in series with each rail, and a voltmeter to probe across each 0.22 emitter resistor to determine the bias current(target is 50mA). Outputs and bias transistor are mounted on large heatsink(Conrad MF35-151.5).
First tests as I slowly bring the rails up to only 1vdc, 2vdc, 3vdc I notice that the rails draw up to almost an amp of current. The voltage across the 0.22ohm emitter resistors reaches about 95 mV(which I calculate as over 400mA bias).
I've checked all my component placement and soldering and it looks fine.
The only changes I made from the stock board were to enlarge the coupling caps slightly, and to locate the VBE multiplier transistor (Q15)on the clamping bar used hold the outputs to the heatink with a 3.5" wiring harness connecting the three transistor leads to the pcb.
I'm afraid to increase the rails any more at this point, until I get some help or advice on what seems to be happening (or is wrong).
I truly appreciate any help at this point!
-Chas
Old 1st May 2013, 07:37 PM   #2
djoffe is offline djoffe  United States
Divide and Conquer is the way.
Remove R32 and R33.
Remove R20 and R22.
Ground the base of Q16.
Ground the base of Q19.
Bring up the power supply slowly. If there's still a bunch of current, then you know that the problem lies in something around Q16-Q21.
Good luck...
Akitika GT-101 Audio Power Amplifier Kit
Update My Dynaco
Old 2nd May 2013, 12:20 AM   #3
clm811's Avatar
Default Q16/Q19 bases grounded; 4 resistors removed
Okay.
First shown is diagram with referenced resistors circled.
Second is diagram showing removal of said resistors, plus
Q16/Q19 with bases grounded, as recommended.
Test setup will remain the same as before when powering up with variac.
Any other recommended test points for checking this circuit as modified?
-Chas
Old 2nd May 2013, 12:32 AM   #4
We're in sync. Check voltage on all emitter resistors of output transistors. That lets us know where the high current goes.
Old 2nd May 2013, 02:11 AM   #5
clm811's Avatar
Default Thanks
Thanks.
I will have to wait until after the work week to proceed further in the testing .
-chas
Old 6th May 2013, 06:16 PM   #6
clm811's Avatar
Default noticed something weird
Haven't had opportunity to fire up the variac yet (maybe tomorrow), but I decided to measure the power supply leads with an Ohmmeter and found the following anomaly:
On Ch R pcb I measured 100 ohms from Vcc to Gnd, 20 ohms from Vss to Gnd and 20ohms from Vcc to Vss, while on
Ch L pcb I measured 20 ohms from Vcc to Gnd, 100ohms from Vss to Gnd and 20ohms from Vcc to Vss.
Any obvious reason(s) for: 1) the resistances being different for Vcc & Vss, and, 2) difference between the R&L channel boards?
-Chas
Old 7th May 2013, 02:15 AM   #7
clm811's Avatar
Default Now with bases of Q16, Q19 grounded.
The above resistance measurements were with the specified resistors removed.
The following are with bases grounded on Q16 & Q19:
On Ch R pcb I measured 70 ohms from Vcc to Gnd, 7 ohms from Vss to Gnd and 20ohms from Vcc to Vss, while on
Ch L pcb I measured 7 ohms from Vcc to Gnd, 70 ohms from Vss to Gnd and 20ohms from Vcc to Vss.
Before I fire up to test with the power supply I'd like to hear opinions on possible reasons for the anomalies between channels.
THX
-Chas
Last edited by clm811; 7th May 2013 at 02:20 AM. Reason: Original post from 2pm did not appear...
Old 7th May 2013, 03:03 AM   #8
godfrey is offline godfrey  South Africa
The schematic shows a (badly drawn) 1K trimpot next to C12. That's to set the quiescent current. You need to adjust it to get the correct voltage across the 0.22ohm emitter resistors. You'll have to undo all the changes djoffe recommended first though.
I decided to measure the power supply leads with an Ohmmeter.....
.....while on
It's a really bad idea to try to measure resistance in-circuit with power applied. Hopefully the meter's not damaged.
Old 7th May 2013, 07:49 AM   #9
clm811's Avatar
I think you misread my meaning.
No power has been applied while measuring resistances of the unconnected Vcc, Gnd, and Vss wires on the amp board.
The phrase 'while on' in the sentence was ",while on Ch L pcb I measured..."
I could have just as well have written ", and on the...".
Sorry if I confused you.
Old 10th May 2013, 07:28 AM   #10
clm811's Avatar
Ordered another set of PCB's (just for the heck of it). Should arrive soon(?).
In one, will insert only components for driver & output stage, so as to completely isolate sections for measurement. In other will assemble only input stage for same reason. Will compare E/I measurements to my built-up boards.
If anyone else has tried these kits please let me know your results:
MA9 S2 Clone 150W 150W 8ohm Poweramp Kit High End MJL4281A MJL4302A | eBay
-Chas
Need help troubleshooting clone ampHide this!Advertise here!
troubleshooting amp kblee Chip Amps 0 18th July 2012 06:51 PM
Help-Troubleshooting & schematic for older NEC A520E amp VictoriaGuy Solid State 14 7th April 2009 07:40 AM
Troubleshooting Amp Mark245 Solid State 6 23rd December 2008 04:12 AM
need help troubleshooting an amp emremeydan Solid State 12 28th January 2008 10:16 PM
Need help troubleshooting an amp cobra050 Solid State 1 6th June 2004 10:13 PM
Copyright ©1999-2017 diyAudio
