Class AC - diyAudio
Old 27th April 2013, 06:15 PM   #1
Default Class AC
I have found the CCDA & Class-AC article and did some modelling and optimisation. A pair of diodes were added in series of emitter resistors to do the actual switching and a resistor to keep transistors open all the time. See attached schematic. Ib is 1A.
Diodes improve Gm curve. I suppose it is due to similar (identical) switching characteristic of all four elements. Furthermore, together with the bypass resistor they might improve switching characteristic compared to switching transistors at higher speeds.
Optimisation goal was to get as constant Gm as possible. Figure below shows a Gm staying within 4.1..5 in -8..8A range. At -2A and 2A a transition between class A and C happens. Visible asymmetry is due to transistor differences. Asymmetrical resistors would help to straighten it as modelling shows.
Has anyone tried something like this? I am considering this as a possible improvement in some of my burnt class AB amplifiers that are waiting to be fixed.
Old 28th April 2013, 12:58 AM   #2
Bigun is offline Bigun  Canada
Bigun's Avatar
Looks interesting. I know Wavebourn likes Class AC too and he's built a lot of good amplifiers.
I think it would be worth your effort to try it out. I would start with the simplest implementation first, even if the simulations show it can be improved on. I suspect that the improvements won't be so important in practice.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 28th April 2013, 03:44 AM   #3
How is the crossover distortion?
You can call me Mad Professor, building crazy experiments in my Electronics Workshop
Old 28th April 2013, 10:45 AM   #4
I did some more optimisation. Now Ib=580 mA.
Schematic with diodes shown.
w.o. diodes is a variant without D25, D26,everything else same.
In graphs you can see distortion signals @ 1 ohm load and dynamic transconductance of stages w. and w.o. bypass diodes.
Looking at these results, benefit of adding diodes is clear. As a side effect at increased currents diodes slightly reduce voltage drop thus increasing dynamic range.
I wonder how things will be when temperature comes in in real circuit.
Old 1st May 2013, 08:55 PM   #5
moschfet's Avatar
With class-ac I have also experimented. With the original circuit I did not become warm.
I then designed the following circuit with Mosfets which also works in class-ac. I've built an amplifier that works very well (Bemos on my private site).
Unfortunately, I do not know how to simulate Gm with LT spice. Perhaps one of you can help me.
Regards http://xipix.de/
Old 2nd May 2013, 12:46 AM   #6
Bigun's Avatar
I wonder if it would benefit if you turned this into a CFP output - just return the drains of the MOSFETs to the emitter of the input devices above the 1 Ohm emitter resistors instead of directly to the output - reducing the resistance of the 1 Ohm emitter resistors to something around 0.2 Ohm at the same time. This creates a feedback loop though which may not be what you wanted.
Old 3rd May 2013, 07:47 AM   #7
load amplifier with 0R (0V voltage source) Vload
drive amplifier with DC sweep
Trace d(I(Vload)) and you will get the dynamic output transconductance.
In general, trace would look like
Code:
d(I(Vload))/d(V(in))
where Vload is load DC source (read 0R load) and in is input net name.
This is based on a definition of dynamic transconductance:
Gm = d(I)/d(V)
~20V AC threw ~100V AC to 12 V AC abcdmku Power Supplies 9 13th January 2013 03:04 PM
Power Supply for Class D: 12V AC mulluysavage Power Supplies 5 18th January 2011 11:16 AM
Mesure DC in AC outlets Cant find what is making noise in my AC 30CCX Help!!! !!! Ulisez Power Supplies 13 23rd November 2010 06:42 AM
WTB: Analog AC Ammeter - AC Voltmeter - Panel Mount dBfreak Swap Meet 1 16th March 2007 10:41 PM
HUBBELL IG3800 clones? AC sockets /AC wire jasonruiz Parts 5 25th April 2003 10:21 PM
Copyright 1999-2017 diyAudio
