Super TMC
Super TMC
Old 26th April 2013, 01:52 AM   #1
jxdking is offline jxdking  China
Default Super TMC
-12dB less THD@100KHz than normal TMC.
My question is, how many poles in there?
Old 26th April 2013, 06:08 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
Great job!
I did not know we can get such much lower THD using several poles.
lineup
Old 26th April 2013, 09:25 AM   #3
The slew rate looks like it is around 20V/Ás.
The phase margin is almost 90░.
Could the 330pF be reduced slightly, to give some performance benefit?
regards Andrew T.
Old 26th April 2013, 09:28 AM   #4
michaelkiwanuka is offline michaelkiwanuka  United Kingdom
Banned
This is very unlikely to be stable.
Old 26th April 2013, 12:22 PM   #5
There is only 1/3 of the output voltage between each 330pF. The slew rate is about the same if you remove all the resistors around the capacitors. In my case, if you remove all the resistor, the equivalent miller cap is about 100pF.
Old 26th April 2013, 12:37 PM   #6
I haven't investigated the stability yet.
I am afraid I am not able to do that with my crappy math.
Old 26th April 2013, 03:13 PM   #7
Banned
Use LTSpice and not Multisim to investigate loop gain.
Old 26th April 2013, 07:34 PM   #8
I will take some time to try LTSpice. Never tried LTSpice before.
I will appreciate that if some one simulate this extreme TMC version before I get the results.
Super TMCHide this!Advertise here!
ThermalTrak+TMC amp dadod Solid State 658 5th September 2017 08:56 PM
How to simulate an OLG of the TMC amp dadod Solid State 76 29th April 2017 08:30 AM
bootstrapsCCS+T-TMC dadod Solid State 162 10th June 2015 06:36 AM
TMC or TPC my dilemma resolved? dadod Solid State 23 2nd May 2011 08:23 AM
What to do with TMC tube radio gear? diamondsouled Tubes / Valves 4 31st March 2009 01:30 PM
Copyright ©1999-2017 diyAudio
