I needed to build a passive preamp with just one source. This is a totally newbie question. I bought 2 10Kohms pots from radio shack, put them in a box, and soldered 2 sets of wires, the input set going to the CD player, and the output set going to the power amp. I tested everything, the resistance varies between 1 ohm and 9.2 Kohms. But when I hook everything up, nothing happens. When I turn the pots, they have no effect! What is going on? Shouldn't 10kOhm make some difference?
Thanks, and sorry if this is too basic. Jam |
#2 |
The wiper (centre pin) of the pot goes to the amp, of the two remaining pins connect one to 0V (screen) and the other to the CD player output. If the volume works in reverse swap the end connections.
I guess you,ve just connected them in series, this won't work. |
#3 |
When its correctly wired up (but not connected) :
The input resistance will not vary - will stay at 10k. The output resistance will vary from 0 (min) to 10k (max). The through resistance will vary from 10k (min) to 0 (max). |
#4 |
Thank you for your responses. I had indeed installed it in series.
| Question on passive preamplifier - transformer section. | binspaul | Analog Line Level | 35 | 7th April 2010 05:43 AM |
| Newbie question: Pot value for passive pre | nina | Chip Amps | 1 | 13th May 2007 07:01 PM |
| please help newbie clip LED passive | garydmd | Chip Amps | 22 | 20th March 2007 01:04 AM |
| PAssive preamplifier (volume attenuator) with Aleph 2? | vmajor | Pass Labs | 5 | 5th February 2005 06:03 PM |
| Newbie question: passive volume control mod for DAC | Ichabod | Analogue Source | 0 | 4th November 2004 01:34 PM |
| Page generated in 0.07764 seconds (68.34% PHP - 31.66% MySQL) with 10 queries |
