relay coil that heats. - Page 2 - diyAudio
Old 24th April 2013, 06:30 PM   #11
sofaspud's Avatar
1W isn't adequate if it must drop 12V at ~100mA.
Could also just remove the 1N4001 and put a resistor on the collector of Q5, and turn the zener 180...
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 24th April 2013, 06:32 PM   #12
Project16's Avatar
I performed the test with the resistance and now the coil does not heat but my resistance test was 1/2w and it was scorching hot!
Thank you all!
Old 24th April 2013, 06:34 PM   #13
Rundmaus's Avatar
Calculate. Though rumours say differently, Ohm's law does not mind being used from time to time.
Rundmaus
Old 24th April 2013, 07:02 PM   #14
jaycee is offline jaycee  United Kingdom
sofaspud, that would defeat the purpose of the catch diode, which is to prevent relay coil back-EMF destroying Q5.
I'd be surprised if the relay coil uses 100mA. I looked up a fairly typical relay for this job, a Finder 40.31 12V, which has a 220 ohm coil and that's 55mA. You could probably get away with 40mA of current and it'd pull in.
edit: Project16, what did you measure for the resistance of your relay's coil?
Old 24th April 2013, 07:15 PM   #15
Project16's Avatar
The relay is an Omron G2R 2, the resistance of the coil is 275 ohms (manufacturer specific).
Old 24th April 2013, 07:26 PM   #16
OK, well because you are going from 24V to 12V that makes things easy - ideally, you want a 275 ohm resistor, but the closest are 270 ohms and 220 ohms.
If we go with 270 ohms, that is 270+275 = 545 ohms. At 24v this gives us 24/545 = 0.044A (44mA).
The power dissipated in our resistor will be P=I^2R = (0.044*0.044)*270 = 0.523W - as you can see, a half watt resistor will be rather hot ! A 2W resistor is best for safety.
A 220 ohm resistor will also work just as well, there will only be slightly more current flowing which will not damage the coil.
Old 24th April 2013, 07:31 PM   #17
Project16's Avatar
Thank you for all these explanations and calculations.
Regards!
Old 24th April 2013, 07:49 PM   #18
sofaspud's Avatar
I saw my use of the zener to be (while reverse-biased) holding the relay coil at 12V. It then becomes the catch diode for back-EMF (while forward-biased). It does double duty.
Old 24th April 2013, 08:02 PM   #19
sofaspud, actually there's an interesting article on Rod Elliot's page about using a Zener to limit back EMF. The important thing is that it does not slow the opening speed of the contacts. However it's not used as a way to run a lower voltage coil on a higher voltage. I'm not sure what the implications of that are, but I wouldn't want to recommend a mod that might degrade the function of the DC protection.
Old 24th April 2013, 08:20 PM   #20
Project16's Avatar
I just thought of something .
One regulator 78L12 type might do the trick in the space of resistance, right?
"Sensitive DC" relay coil VMat Parts 7 18th November 2012 09:24 PM
Found perfect relay replacement - but coil resistance is off. Which one is better? Coconuts 500 Parts 5 1st September 2012 05:38 AM
Buzzing AC relay coil kavermei Tubes / Valves 5 11th April 2010 01:53 PM
Single coil latching relay control?? cal34 Parts 0 15th February 2009 08:33 PM
relay coil on ESP's project- bd139 equiv? ThSpeakerDude88 Car Audio 9 23rd January 2007 03:24 PM
Copyright 1999-2017 diyAudio
