Please help me solve my ground loop issues - Pics and layout attached.
Old 23rd April 2013, 11:38 AM   #11
CopperTop is offline CopperTop  United Kingdom
Do we know which transformers are suitable for 'Class II' and which aren't? All we need to know is that the secondary cannot become live. We can earth the enclosure as long as we keep the connectors isolated, and ensure that even detached mains wires cannot physically touch anything after the transformer. I could live with this arrangement.
As an example, would this transformer be suitably approved?
MCTA250/40 - MULTICOMP - TRANSFORMER, 250VA, 2 X 40V | Farnell United Kingdom
It says in the data sheet
Termination:
All leads tri-rated UL1015 style cable rated 600 V / 105C VW-1
Primary leads double insulated with PVC sleeving for a minimum of 20 mm
Lead lengths 5 mm approximate all leads ends tinned to 6 mm
Pri / Seconds leads O
Standards:
Designed and manufactured in accordance with:
EN60742 (Non short circuit proof),EN60065 (IEC65), EN60950
UL recognised to UL1411, 2601-1 and UL1950 under family approval file E115159
All we need for peace of mind is to know is whether the primary->secondary insulation is approved, but the words 'Class II' or even 'double insulated' with respect to this, are very hard to find anywhere.
Old 23rd April 2013, 12:00 PM   #12
R.I.P.
Coppertop,
ask your house and contents insurance company if they will insure you against the risks of your version of ClassII equipment becoming faulty and killing someone?
regards Andrew T.
Old 23rd April 2013, 12:42 PM   #13
Originally Posted by AndrewT View Post
Coppertop,
As I suggested in my first post earlier, the dogmatic "All exposed metalwork must be earthed" line is easy to say, but doesn't actually offer a solution. If the home constructor is going to build an amplifier and use it with an earthed computer, say, is there an approved way of doing it that doesn't give rise to ground loops?
In the absence of anyone telling them how to do it properly, they're going to come up with their own potentially risky solutions.
You know about this stuff. Just tell us how to do it!! :-)
Old 23rd April 2013, 08:57 PM   #14
Fusion916 is offline Fusion916  United States
... Does anybody have any suggestions for my setup/layout/etc? So far the discussion has centered around the theoretical, but is the only solution to not use the earth ground in my active crossover?
Old 23rd April 2013, 09:17 PM   #15
Conrad Hoffman is offline Conrad Hoffman  United States
Maybe I'm just lucky but when my system was tri-amped, the preamp, the crossover and all three stereo power amps had the line ground connected directly to the chassis, all circuit grounds connected to the chassis and there was no hum problem. The trick is where those connections should be made.
There should never be current flowing in shields, one of which is the chassis. I connect mains ground to the chassis right where the module is, or the cord comes in. Everything else connects to a master ground point, which is usually located at the power supply, and that point also connects to the chassis at a single point close to the power supply. Most RCAs have ground wires that also run to the PS master ground, though my power amps usually mount the RCAs right to the chassis. Finally, everything plugs into a power strip, never into widely separated outlets.
Probably not to the best theory, but it works without fancy ground breaks using resistors or diodes.
I may be barking up the wrong tree, but at least I'm barking!
Please help me solve my ground loop issues - Pics and layout attached.Hide this!Advertise here!
Need help with 60hz hum/ground loop. Schematic attached. Fusion916 Solid State 32 11th October 2012 08:25 PM
Methods of Handling Various Devices and Grounding - Ground Loop Issues mattwalston Analog Line Level 7 10th January 2012 11:08 AM
ground loop layout mosfetmaster Solid State 4 7th January 2011 07:11 PM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 06:46 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
