the Golden Gain Ratio
Old 24th April 2013, 07:36 AM   #11
Stee is offline Stee  Italy
Stee's Avatar
Default What do you understand
is not the message of the project : Shhh:
the theme is set to gain ratio : Joker:
then comes the architecture
then comes the sizing
and the choice of components
the rest are all sterile chat: (
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 24th April 2013, 09:04 AM   #12
tomtt is offline tomtt
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
once the, 'you can't do that' people calm down,
something interesting might appear in this thread .
Originally Posted by GoatGuy View Post
Optics.
Maybe some of us remember back to the nicer cameras of the 1950s ...
have a friend, who still takes his Speed Graphic with him everywhere ...
Old 24th April 2013, 11:37 AM   #13
Ian Finch is offline Ian Finch  Australia
Originally Posted by Stee View Post
.....the theme is set to gain ratio : Joker:.....
Ok, let's be specific: Why do you consider the ratio between open and closed loop gain significant?
Do you believe the ratio is constant in an amplifier over the audio bandwidth so this can be a
meaningful design goal or are you assuming that setting it a particular frequency is adequate?
There is nothing so far to support your assertion.
If only I had listened....
Old 24th April 2013, 12:21 PM   #14
Stee's Avatar
http://www.esafono.it/1TO100RULE.pdf
is an aesthetic relationship of the acoustic scene
acts as a rebuilder of space as expander
Old 24th April 2013, 01:03 PM   #15
soldersplash is offline soldersplash  United Kingdom
Nothing new here, surely?
The document just described a low NFB amp with output transformer to lower output impedance.
I suspect it measures badly but sounds, what's that word I see around here, errr.. euphonic!
There is no Golden Rule for open loop to closed loop or loop gain ratio. These ratios will vary from design to design and from topology to topology and with performance goals; and as already stated, within a given design these parameters are not one dimensional, they vary with frequency, temperature and possibly more.
Old 24th April 2013, 01:10 PM   #16
DF96 is offline DF96  England
Complete nonsense! It advocates using just enough feedback to ensure the presence of re-entrant distortion, but not enough to reduce all distortions. Barmy ideas expressed in poor English.
Old 24th April 2013, 02:04 PM   #17
OK, no technical reason - just Stee's aesthetic number rules.
These thematic designs you post and illustrate on your website are certainly imaginative and must make wonderful copy
for impressionable people to read but if the ideas crumble at the first level of inquiry, surely you must have doubts about
their value compared to established audio design theory. I don't mean to say categorically that you are wrong, if that
actually matters to you, but the onus is heavily on you to prove your claims by demonstrating that they can at least work
correctly as power amplifiers.
Otherwise, demonstrate their benefit by simulation or other evidence first. There are nebulous combinations of components
that can amplify audio but few ideas are worth building or even serious consideration. Let's see some that really can work
and deliver on the promise of the glowing descriptions and titles you give them.
I'm actually for a little imaginative thinking, perhaps as tomtt suggests, because this enables us to move on to new areas
and possibilities but you can't get there without a proven basis to build ideas on. That won't come out of the ether or from the
elaborations and chip-level techniques of opamps without a grounding in what is actually needed. Meantime, start simpler
and build from there - with purpose.
Old 24th April 2013, 02:10 PM   #18
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
There is nothing here. Stee's "designs" are unattributed work of others, and I believe "entirely" also applies. They're cut'n'paste frankensteins.
Old 24th April 2013, 06:13 PM   #19
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
FWIW I found Stee's posts and links at an Australian Audio site.
*We* are showing lots of open mindness; there they weren't commented, not even to rebuke them.
The deafening silence of the open desert.
Looks like the Aussies are more practical minded than us, and don't have much time for idle pointless "discussions" ... or so it seems.
Old 24th April 2013, 07:13 PM   #20
GoatGuy's Avatar
JMFahey ... for a certain amount of comedy, check out the design of post #11 ... after scratching my head endlessly, I think the entire "front end" is a do-nothing amplifier. Basically a fancy source-follower. The driven transistors on the righthand section certainly don't look power hungry. So... that and missing resistor values everywhere ... leads me to believe this is just "design salad".
Further apart from the enthusiastic 24/40 label of golden ratios, there appears to be nothing in the circuit that could achieve such precision.
GoatGuy
the Golden Gain RatioHide this!Advertise here!
golden ratio. I dont get it murphythecat8 Multi-Way 84 14th December 2012 03:04 AM
The Golden Ratio of 1.618 PrecisionAudio Multi-Way 43 11th October 2012 03:15 PM
The Golden Ratio Stage Stee Solid State 7 22nd February 2009 08:46 PM
Golden Ratio Height edjosh23 Full Range 13 3rd February 2009 09:52 PM
Golden ratio - Example? icebear Multi-Way 5 17th April 2004 08:40 PM
