Hi, I am building a SS-Guitar amp and i want to build a very simple preamp for an AUX-Input to play with backing tracks. Can I put 2 preamps on 1 board and use the same power supply for both ? Or will the 2 preamps influence each other ? I thought I just take 2 inputs, and mix the signals together in 1 output, which goes in the poweramp.
Since you are mixing them anyway, interaction is the least of your problems.
Plus the CD signal will have very little gain and will be mixed at high level practically at the Power Amp input, so ....
Go ahead, it's an easy task.
Have a look at the way others do it (Laney/Fender/Marshall/Peavey/etc.)
