This meter pegs but amp works fine This meter pegs but amp works fine - diyAudio
Old 11th April 2013, 06:26 PM   #1
srinath is offline srinath  United States
Default This meter pegs but amp works fine
Hi all,
The circuit for the meter is attached.
This is what this amp does - and its a nad 3080 integrated.
The right power meter pegs as soon as its powered up. Then a few sec later the safety clicks and it functions as it were normal. The right and left are equal, though the right meter never gets off the right end peg. Then when you turn it off, it takes 5 mins and slowly gets to 0.
With the amp unplugged - I've measured Dc across the meter terminals and its like 1.3 or so and it slowly drops to 0. Shorting the 2 posts causes the thing to temporarily swing toward the 0 but when you let go it usually returns to where it was
Anyway hope someone can help, I'm afraid to run the amp fearing it may blow.
Thanks.
Srinath.
Old 11th April 2013, 06:34 PM   #2
Mooly's Avatar
Remove the 10uf cap. The meter should not move. If it doesn't then check the cap. If that's OK then the amp is oscillating at HF.
If that is all OK then measure the voltage across the diode. Is it around 0.7 volts (should be identical to the other one) ? If that's OK then either a resistor is faulty or the transistor is leaky.
Old 11th April 2013, 06:49 PM   #3
OK let me re word it so I understand - C202 get removed. If meter is dead, bad cap. If meter is not dead amp oscillates @ HF. What does that mean ? Sounds bad - but both channels sound fine @ all times.
Now after replacing c202 with a good part, voltage cross d204 - with it in or out ? should be .7v. If it is, then a resistor is bad or the transistor is bad.
Cool.
Srinath.
Old 11th April 2013, 07:02 PM   #4
Mooly's Avatar
1) Take the cap out. If the meter now reads zero it means either the cap is bad or more likely, the amp is feeding HF (that you can not hear) into the meter circuit.
2) If the meter is still faulty with the cap out then you have a simple issue with one of the components in the meter drive circuit.
Old 11th April 2013, 07:27 PM   #5
Ok let me see if I can get to it in a bit.
Thanks.
Srinath.
Old 11th April 2013, 08:12 PM   #6
The meter pegs with c202 removed.
So the rest of the components - Let me see what the resistors look like outside and ow the measure up.
This is my kind of analysis - removing components till the problem stops.
Cool.
Srinath.
Old 11th April 2013, 08:58 PM   #7
FoMoCo is offline FoMoCo  United States
I'm thinking a shorted transistor...
Account Deletion Requested: 1/26/2014
Old 12th April 2013, 06:13 PM   #8
Ding ding ding ... removing the bc546b gets that meter to sit still.
Swapping the transistor from the other channel makes it work fine (I think) cos I have removed the 620 ohm resistor and fiddled the trim pot vr202 on the bad channel. It seems to slowly climb to 0.5 watts but sit there and not climb further. I will replace the transistor and the resistor and see where that gets me. Thanks guys.
Cool.
Srinath.
Old 12th April 2013, 06:31 PM   #9
Mooly's Avatar
My money is on the transistor or the diode. I'd be very surprised if a resistor were out of spec.
Have you measured them on a meter ?
Old 12th April 2013, 06:36 PM   #10
I pulled that resistor - in a misguided attempt to see if it was going to make a diff - and that destroyed it.
Cool.
Srinath.
This meter pegs but amp works fineHide this!Advertise here!
Everything works fine till i plug in SubWoofer ideagrapher Everything Else 1 5th September 2012 06:10 PM
TPA3122 works fine on battery - starts clicking on powersupply. Cyberzim Class D 50 9th September 2011 06:11 PM
Sub not working with CD (works fine with radio or iPod) puttsthree Car Audio 4 27th December 2007 06:26 AM
Copyright ©1999-2017 diyAudio
