CA9 Schematic needed
Old 6th April 2013, 01:36 AM   #1
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Wink CA9 Schematic needed
Hello
greetings can anyone help me with CA9 SCHEMATIC chinese amp AB CLASS
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 6th April 2013, 01:47 AM   #2
angeltech is offline angeltech  Philippines
Send a message via Yahoo to angeltech
Sir:
http://www.crestaudio.com/media/sche...matic_set1.pdf
please check hope this help.
Angeltech
Old 6th April 2013, 01:55 AM   #3
Hi Angeltech
greetings the CA9 schematic i am looking for is the chinese version of crest audio not orignal CREST AMP its ab class 1200 watt in 2 ohms thanks for your kind help
warm regards
andrew lebon
Old 6th April 2013, 02:07 AM   #4
Default some pics of CA9
SUPPLY IS 120 VOLTS DC+/-
Old 6th April 2013, 09:30 AM   #5
Is this the Circuit of CA9 china? looks it is single sided board and can be cloned easily hehehe
Old 6th April 2013, 09:34 AM   #6
Walkalone is offline Walkalone  Viet Nam
1200W class AB @2 Ohms in with the rail is +/-120V?
It's impossible with 2SC5200/2SA1943. They have Vce is only 230V, and very small SOA.
Old 8th April 2013, 12:08 AM   #7
Wink CA9
TRYING to clone it will use MJL4281 and its complement
warm regards
andrew lebon
Old 8th April 2013, 01:30 AM   #8
ravpreet420 is offline ravpreet420
nice work.....
Old 8th April 2013, 06:22 AM   #9
I think can get lower the rail and use MJL21193/MJL21194 to larger SOA, safety if you run they at 2R load.
ON Semi MJL21193/MJL21194 have 1.8A@100V@1sec.
100VDC can get 500W per 8 Ohms load (about 63VAC @ 8R, 8A => need 5 pairs to load 8 R and double to 4R.)
Old 8th April 2013, 09:09 AM   #10
Great you need not schematic I think, you already made it into reality nice job...
keep us updated...
regards,
Angeltech
CA9 Schematic neededHide this!Advertise here!
Crest CA9 / P.Audio PA9... differences?! promax Solid State 0 28th June 2011 06:54 PM
Schematic needed panasonic RX-1230 schematic Buzzsaaw Analog Line Level 0 23rd April 2011 08:52 PM
Crest CA9 spare input boards? megajocke Solid State 6 6th November 2008 04:17 PM
Schematic needed Skoda_101 Solid State 0 15th May 2006 04:12 PM
Needed schematic.... di4kata Tubes / Valves 8 14th June 2004 08:21 AM
