Voltage regulator adjustment
Old 5th April 2013, 06:21 AM   #1
limono is offline limono  United States
Default Voltage regulator adjustment
What would be the simplest way to increase voltage in HV section from 250V to 300V ? TIA , L
Old 5th April 2013, 06:31 AM   #2
UV101 is offline UV101  England
UV101's Avatar
You could try lowering the 500r between pins 2 & 3 of the lm317 but it will depend on the input voltage as to if you can get to 300v.
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 5th April 2013, 07:39 AM   #3
Input voltage is 350V. Load current is less than 10mA . I think it's possible.
Old 5th April 2013, 09:13 AM   #4
ChristianThomas is offline ChristianThomas  United Kingdom
Location: On a hill, in a wooden shack, next to the woods, in Somerset.
The formula is always the same. 1.24V times the gain + the tiny amount of the adj current. Either do as UV101 suggests or increase the 100k resistor. Dropping the 500 ohms is probably the better of the two as it adds a bit of current draw and will likely lead to less variation with load.
Old 5th April 2013, 09:18 AM   #5
lineup is offline lineup  Sweden
lineup's Avatar
Change the 100k resistor in LM317 to 120k.
Or add 20k to the 100k resistor.
This should give like 300V output
lineup
Old 5th April 2013, 10:18 AM   #6
R.I.P.
with 10uF on the adj pin you must add diode protection from adj to out.
regards Andrew T.
Old 5th April 2013, 01:56 PM   #7
OK , Thank You guys .If I find 120k/5W in my junk bin ,I'll try it first . If not I lower 500R a little bit , easier to get small wattage resistor. And LM317 has hefty heatsink so upping current want be a problem either.
Old 5th April 2013, 04:19 PM   #8
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
For 10mA you really should use a HV regulator.
The LM317 will work but you have a huge gain (120k/500R) which means the regulation gets worse in the same ratio.
jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 5th April 2013, 10:49 PM   #9
Actually it's 1.7mA for a channel so 3.4 mA for both . I didn't want to mess with it too much. ( the psu unit ) I don't know why people who made it went for Maida regulator . I put Cree Shottky rectifier diodes , dropped resistor from 500R to 420R and it took care of the business. I will listen to it a little (sounds pretty good )and than maybe go passive with chokes and tube gas regulators . Thank you for your help. Best Regards, L
Voltage regulator adjustmentHide this!Advertise here!
Need help with tracking regulator adjustment. Please. G Solid State 7 23rd September 2014 08:38 PM
on chip negative voltage regulator with positive supply voltage gvsrkprasad Power Supplies 3 20th February 2013 02:19 PM
Regulator adjustment Prune Parts 6 16th June 2010 03:53 AM
Auto Voltage adjustment--Principle explain GPE Power Supplies 2 2nd May 2008 03:50 AM
Who's right re bias adjustment versus plate voltage brownbr Power Supplies 3 16th June 2006 06:26 PM
