quasi-balanced working method - diyAudio
Old 4th April 2013, 07:02 PM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default quasi-balanced working method
The method allows the quasi-balanced amplifier with working conditions is optimized.
two amplifiers identical bridged generate power on the load when the second sees reduced the level of the input signal.
the minimum is still guaranteed by the internal feedback
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 4th April 2013, 09:36 PM   #2
Stee's Avatar
Default see the power results
between two different amplitude
Old 5th April 2013, 09:19 AM   #3
PetruV is offline PetruV  Romania
so what makes it so special,what advantages does it give
Just a kid who likes building and modding things.No inspirational quote here for you
Old 5th April 2013, 01:17 PM   #4
ilimzn is offline ilimzn  Croatia
And the answer is, none at all, in fact it has serious drawbacks. One amplifier sees completely different operating points within it's output stage SOA compared to the other. The one with reduced output is under considerably more strain, as the current through the output stage is dictated mostly by the oposing bridged amp, while the NFB reduces output voltage, meaning increases voltage drop on the output devices.
Just because it's different it does not mean it's a good idea. In fact, in all honesty, I have yet to see one from this author?
Old 5th April 2013, 09:43 PM   #5
Stee's Avatar
the gain of the bipolar devices is much higher than the power required for domestic use
this method can reduce the power output without reducing the optimal regimen of work
Balanced quasi-floating output xocoatl Parts 5 4th August 2014 01:02 PM
Quasi or not Quasi - that is the question x-pro Solid State 31 20th October 2013 04:25 PM
Quasi-Balanced Method Stee Solid State 16 3rd November 2009 06:45 AM
Copyright 1999-2017 diyAudio
